Thread: Pool calculator for Android devices?
    May 2013
    Chandler Arizona
    78
    I did a quick search for the pool calculator yesterday. I see theres an App for Iphones. Is there any plans to get App created for Android? I'm sure many people are willing to pay $$.
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    Aug 2013
    Ohio
    21
    Re: Pool calculator for Android devices?
    I have been using Pool Pal. Its free. You put in current and target levels and it says what to add. Also stores entrys by date so you know what you have used when you backwashed ect. Has a notes section for the individual journal entrys. I still use poolcalculator to be sure but its nice to store my test results and such.
    18 x 36 in ground vinyl liner
    26000 Gallons
    Hayward 1hp superpump
    Sand filter
    Power Ionizer
    May 2013
    Chandler Arizona
    78
    I did use that (pool pal)yesterday and it did not save all my inputs, I input 2 pools, mine and my brothers readings from our pools went back in and setup defaulted to initial setup?? I was going to play with it again today to see if i needed to change some settings.
    38,370
    Simple Pool is also developed by a member here.
    mmn's Avatar
    Jul 2013
    South Florida
    34
    If you have internet access, the Pool Calculator does work in the Android browsers. I believe it will also work stored locally for when you are not connected to the inter web.
    Regards
    Michael
    14,288 gal IG freeform Diamondbrite
    Hayward 9002 filter
    3/4 hp Hayward pump
    Barracuda G3 cleaner
    TF-100 test kit
    resurfaced 6/2013
    Donldson's Avatar
    NW Ohio
    2,904
    I use this myself, works well. Much easier than trying to use the pool calculator on a phone screen!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
