Thread: Filter sand entering pool thru return
    We are newbies.....pool was installed the other day, when we turned on the filter, there is sand entering the pool thru the return jet.
    What could be wrong?
    Any suggestions about what to check?
    Mar 2007
    Morris, IL
    Re: Filter sand entering pool thru return
    I think that I would not worry about it for a bit here. Some sand may have gotten dumped down the main pipe on accident. If it continues then you may have a cracked lateral which would need to be repaired. Did you install everything or a company? If a company it may not hurt to give a call and let them know that there is an issue right away so that they cannot say that you abused it somehow.
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    It was installed by a company, and they have been contacted.
    Thanks very much for the reply!
    What a pain! But hopefully it'll be fixed soon...
