Thread: Phos Free
    Wildcat's Avatar
    Jun 2013
    309
    Phos Free
    I have a couple of bottles of Phos Free and one bottle of Pool Perfect. I bought and used them before I found TFP. Other than very high CYA, go figure, my pool has been algae free and clear. I am switching to BBB, hampered only by high CYA levels and the reality of not draining 6000 gallons in a desert environment. Might these two additives act sort of like an extra filtering agent in my cartridge filter, much like DE in a sand filter, or should I just dump them?
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Phos Free
    Phos Free does nothing for filtering, but do lower your phosphates, so make it harder for algae to get established, the only thing is if your at the point of algae getting established you already have an out of balance pool.
    Re: Phos Free
    Neither of those is going to help your filtering at all. Pool Perfect is very handy if you have the problem it is designed to solve, large quantities of oil (typically sun tan oil), otherwise it is useless.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Phos Free
    Neither product will help with filtering, but I would hang on to them until after your next pool party where you could use the Pool Perfect to mitigate any excess suntan oil. Even though phosphates are a non-issue in a properly chlorinated pool, the Phos Free will lower whatever phosphates may be in the pool. Right as I was converting to BBB, I used up my existing Phos Free - it will not hurt anything. Once it was gone, I did not purchase any more after I learned that proper chlorination will keep algae at bay regardless of the pool's phosphate level.
    Wildcat's Avatar
    Jun 2013
    309
    Re: Phos Free
    Thanks, you all reinforced what I suspected
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Phos Free
    PhosFree does contain a clarifer in it; otherwise, the lanthanum carbonate that forms in a pool would severely cloud it and take days to filter out. Some phosphate removers don't contain a clarifier, but PhosFree does.
