Thread: protecting vinyl liner corners
    Aug 2013
    Ohio
    21
    I have been reading that these are the first to fail. I'm new to pools and wondering if I can armor all them or use something else to protect them.
    Bought a foreclosure and pool had sat for many years. Had to scoop out literally a ton of muck. Replace the liner, pump and filter sand. Return lines were cracked so also ran 2 new ones. Would like to make it last as long as I can after going through all this this year.
    18 x 36 in ground vinyl liner
    26000 Gallons
    Hayward 1hp superpump
    Sand filter
    Power Ionizer
    May 2012
    Northern Connecticut
    103
    Re: protecting vinyl liner corners
    We would love to see before and after pics!
    24,000 20x42 double roman end in ground pool being built. Start date june13, 2012.
    Finished July 4th, 2012, sports pool, vinyl,SWG, DE filter, fountains. Heat pump,
    First Pool Ever!
    Aug 2013
    Ohio
    21
    Tried from my phone and they wouldn't go. Will get them to my comp and try from there.
    26000 Gallons
    Sand filter
    Power Ionizer
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Try this thread.
    There's actually a better product to use.
    www.troublefreepool.com/using-armor-all ... 53857.html
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Aug 2013
    Ohio
    21
    Quote Originally Posted by y_not
    Try this thread.
    using-armor-all-on-liner-waterline-t53857.html
    Thanks deffinitly picking up some 303.
    Added some pics on a separate thread.
    post559078.html#p559078
    26000 Gallons
    Sand filter
    Power Ionizer
