Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Pentair 250M Minimax Heater
    Apr 2013
    Suburbs of Chicago
    76
    Hello All,
    Today I tied the PVC back into the heater in hopes of the heater would work. The heater is a Pentair MiniMax 250M Minivolt Heater. Well as I figured it wouldn't be as easy as turning on a switch because it does not want to kick on. I took the front panel off and turned the gas valve to Pilot and hit the ignition, and the pilot stays lit. Then after I have the water running through it and I turn the switch to Pool and have the temp knob to hot. The burners don't come on...?
    Some questions:
    1. As I am looking through the manual it says there should be a lit diagnostic board showing power, service needed, ect. Well I don't see anything lit up on the front.
    2. Does this heater get its electricity from the water running through it? Because I don't see any signs of electric running to it.
    3. Any test I can perform before having to call a service company in hopes of being able to do it myself.
    Here are some pictures
    [attachment=0:2pq3gc82]pool_heater_3.jpg[/attachment:2pq3gc82]
    [attachment=1:2pq3gc82]pool_heater_2.jpg[/attachment:2pq3gc82]
    [attachment=2:2pq3gc82]pool_heater_1.jpg[/attachment:2pq3gc82].
    Thanks
    Fiberglass/Concrete IG
    Pool Size: 16500 gallons
    Filter: Hayward S244T Pro Series Top-Mount Sand Filter
    Pump: Hayward 1 HP Super Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Pentair 250M Minimax Heater
    Quote Originally Posted by BNighGrow
    Hello All,
    Start simple. You turned it to Pilot and lit it and it stays lit. Did you then turn the knob to "On"
    Jun 2012
    western NY
    1,563
    Can you see in where the pilot is lit? There should be a "probe", about 3/8" diameter, engulfed in the flame. This is the powerpile that supplies the millivolts to power the gas valve. It is possible that this is not putting out the proper amount of voltage for the valve to work. If you have a multimeter you can test for the voltage from this. Ideally it should be 750 Milivolts. They can work as low as 300-350 mv.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Apr 2013
    Suburbs of Chicago
    76
    Ha sorry, Yes I turned it to Pilot for a minute or two, then turned it to "On" and it stayed lit.
    Then I turned on the filter, then turned it to pool (also tried spa) with the Temp knob all the way to hot.
    Nothing happen, no noise, and water was not any warmer, and got on my stomach and couldn't see the other burners on.
    I do have a multimeter, what exactly should I be contacting with the multimeter? I see the "probe" you speak of where the only flame is coming out.
    Have exact same system and issue.... Watching attentively.
    Mel
    http://vinylcoveringsbymel.com/
    we keep you coverd
    Made in the USA
    Jun 2012
    western NY
    1,563
    In your last picture there is a wire (two conductors, red/white) hooked to the gas valve coming in from the right side. The white is hooked to the TH/PP terminal and the red is connected to the PP terminal. That is your powerpile wire. To test it, hook the leads of your meter to each of those. It can be done with them connected but it is better unconnected. Looking at the pictures again you may want to clean up all of the connections as any slight corrosion will cause resistance in the circuit and the voltage is very low on this type of system. If you find that the Milivolts is good then another test to try is to bypass the control circuit by hooking a jumper between the TH/PP terminal and the TH terminal. If you have a good powerpile and gas valve the burners should fire right up. If this happens then you have a bad sensor somewhere in the wire going out from the TH/PP terminal and back to the TH terminal.
    In the image I posted the "D" terminal is the same as your TH/PP terminal, "E" is your PP term, and "F" is your TH term. Part 5a and 5c is your powerpile.
    Any chance someone can recommend where to buy a replacement powerpile? my local pool shop thinks it will be $90 which seems steep....
    perhaps in WNY as I am in Niagara....
    Mel
    we keep you coverd
    Made in the USA
    Jun 2012
    western NY
    1,563
    Quote Originally Posted by jrross
    I am about 70 miles south of you. Down here we have a couple of local HVAC supply houses that I can purchase from. I am sure you have them in your area too. Do you have a heating contractor that you have dealt with in the past? They can be a good source for these items. I agree, $90.00 is a bit steep, $30-$40 is more like it on the retail side and $15-$20 on the contractor side
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    If you do a Google search for the part#, 071515, the prices range from $45 to $70.
    http://www.parts4heating.com/Pool-Heate ... -s/786.htm
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Jun 2012
    western NY
    1,563
    Just found this one located in buffalo. He may let you pick it up in person... http://www.ebay.com/itm/REPLACEMENT-750 ... 2317f5f4a0
    Awesome thanks for the help guys...
    Mel
    we keep you coverd
    Made in the USA
    Ok so i replaced the powerpile and still no go... Tried jumping the circuit and nothing.... What next?
    Mel
    we keep you coverd
    Made in the USA
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    So with the pilot lit, you tried jumping out the gas valve and it wouldn't do anything?
    Paul
    Quote Originally Posted by ps0303
    correct
    Mel
    we keep you coverd
    Made in the USA
    Jun 2012
    western NY
    1,563
    Do you have a meter to measure the voltage from the powerpile? We need to verify what milivolt reading you are getting from the powerpile.
    no I don't... guess I should just call someone....
    Mel
    we keep you coverd
    Made in the USA
    Aug 2013
    SW Michigan
    17
    Wow!
    I have the exact same unit and had the exact same problem ..........twice in 10 years.
    In my case, the problem turned out to be a balky pressure switch. It's a $5 item that costs $29 at the local pool store. But it's easy to replace yourself if you're so inclined - two wires and and a small wrench.
    For testing purposes, the switch can be bypassed by merely connecting the two wires together.
    Jun 2013
    Stilwell, Kansas
    26
    I have basically the same heater (I have the 150M model) and I have the same problem (pilot lit, but heater won't fire). I tested the voltage across the thermopile leads and only got 185 millivolts. Does this mean the thermopile needs replaced? Or might it just be that it needs cleaned or something?
    Empty 16'x32'x(8' deep end & 4' shallow end) indoor inground pool, ~23,000 gallon, Sta-Rite 3/4HP pump, Minimax 150M Plus millivolt heater, Heldor PF-50 sand filter, Pentair Sand Dollar SD80 sand filter, Hayward Aqua Rite SWCG (T-Cell-15)
    After changing my Thermopolis without it helping... Changed out the thermostat module (3 inch square black box behind the knows panel and she fired right up...) hope there's no other issues.... Good luck guys.
    Mel
    we keep you coverd
    Made in the USA
  20. Back To Top    #20
    Jun 2012
    western NY
    1,563
    Quote Originally Posted by codyt
    That is a pretty low reading. Make sure the thermopile is in the pilot flame real good and you have a strong flame. Also make sure there is no corrosion on the leads which would give a low reading as well. If all that is good then I would suspect the powerpile to be weak. I have pulled them out before and tested them in the burner on my gas stove to be sure. Idealy you should see 750 Mv if it is good. They will range a bit above or below that number... 600-800 out of the box.
