Results 1 to 7 of 7
Thread: fc level
    May 2013
    Cyprus
    159
    fc level
    Hello boffins
    I am just getting to grips with this site :P and you say that fc should be between 3-7 but my test kit indicates a level of 1-2 can someone explain the difference. I know that each pool has slight differences but how do you work out what these are
    Living in Cyprus
    Still enjoying life
    Re: fc level
    test kit recommendations don't take into account cya levels. they recommend 1-2 ppm fc and then shock weekly. if you maintain fc levels per cya readings then you never have to shock and pool stays sparkling.
    24,000 gallon ig fiberglass pool
    1 hp hayward pump
    hayward sand filter (250 lb)
    madisonville, ky
    May 2013
    Cyprus
    159
    Re: fc level
    Thank you
    Clarity is everything
    Living in Cyprus
    Still enjoying life
    Jun 2012
    Howell, NJ
    977
    Re: fc level
    It's all because the pool industry refuses to acknowledge the relationship between CYA and chlorine. CYA buffers the chlorine. In fact, there is more active chlorine in tap water (unless you have a well) than there is in a pool that is stabilized by the CYA.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    May 2013
    Cyprus
    159
    Re: fc level
    Dam
    My test kit only measures fc to 5 in a colour scale of 0.5-1-1.5-2-3-5 and the recommended value is 7 ish I will just have to spend some money and get a good test kit luckily I have some friends visiting this month.
    Living in Cyprus
    Still enjoying life
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Re: fc level
    A good test kit will SAVE you money and time in the end. You will LOVE being in control of your pool.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: fc level
    The test kit matters. You want one with a FAS-DPD chlorine test kit, specifically either the TFTestkits TF-100 or the Taylor K-2006. See the Pool School article Test Kits Compared.
