Results 1 to 8 of 8
Thread: Replacing Salt Cell
    Replacing Salt Cell
    All
    I'm pretty sure my salt cell has died. Its only 2.5 years old as the original owner replaced it on Mar 2011. Wont generate chlorine cause it reads a low salt (2300) used salt test strips which tell me it;s closer to 3400. Test water and chlorine is not being generated as I am having to temporarily add bleach to keep it decent.
    Anyway wanting to find out how do I know what kind of cell i can replace it with or is compatible. I have the AquaLogic PS8, the current salt cell is a Hayward Turbocell GLX-T-5. (20k gallon) Would like to avoiding getting this one again as its a bit pricier than some other options.
    11K SWG Freeform IG pool w/ spa; Bluehaven 550 (hayward mfg) Cartridge Filter; Century Centurion 2HP Pump on pool; Hayward 400H heater; Polaris PB4-60 Pump on cleaner; Hayward Super II Pump on waterfall, Hayward TurboCell GLX-Cell-5; AquaLogic PS8, Taylor 2006k
    Pool Chlorinator @ 80%; Filter from 11AM-6PM, Cleaner from 11AM-2PM
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Replacing Salt Cell
    Have you cleaned the cell lately? Chances are that it has a coating of calcium deposits on it, which will interfere with the action.
    Yes cleaned the cell 3 months ago and when it started acting up again 2 weeks ago i cleaned it again with no luck.
    Jun 2011
    Long Beach, CA
    2,788
    How much are you looking to spend, the T-5 cell is only $210 on amazon? You should be able to use the T-15 cell and run it at a lower % and get longer life out of the cell, but it does cost more.
    Ping, where were you able to find the GLX-T-5 Cell on Amazon forn$210. Just tried searchingband couldnt find that price
    Jun 2011
    Long Beach, CA
    2,788
    Ah okay the 15k gallon one. Its different that what i currently have (turbocell glx-cell-5). How would i know if this linked salt cell is compatible with myb aqualogic PS8 automated system?
    Jun 2011
    Long Beach, CA
    2,788
    Here is a link to Hayward, http://www.hayward-pool.com/prd/In-Grou ... 4006_I.htm.
    The Hayward cells are T-5 15,000, T-10 25,000, or T-15 40,000 gallons. It looks like they are interchangeable and you buy the cell that you need for your pool. I would opt for a T-10 or T-15 cell for your pool size.
