Thread: Testing CYA...
    May 2012
    North of Charlotte, NC
    312
    Testing CYA...
    My neighbor has a green bloom and I'm gonna take my TF100 down and hopefully show him the light , fortunately I've never had anything but crystal clear water since finding TFP..my question is how accurate or possible is testing CYA with greenish water? I can only assume it can be done but may be a little harder?? At least I know I can't figure out his shock level without at least knowing his CYA
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Testing CYA...
    Take a reading in the view tube with plain pool water and see how cloudy it is. Then you'll know how skewed the results may be. I'll bet it won't have any effect.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Testing CYA...
    Now there's a question I haven't run across or thought about before. Duraleigh?
    May 2012
    312
    Re: Testing CYA...
    Quote Originally Posted by Richard320
    Will do, thanks Richard....
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Testing CYA...
    Quote Originally Posted by woodyp
    Shame on you!
    Very rarely, cloudy or murky water can affect the CYA test. To check for this, fill the view tube with straight pool water. If you can still see the black dot clearly, the cloudy/murky water is not affecting the test result.
    http://www.troublefreepool.com/exten...ns-t25081.html
