Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Balancing Water Before SWG Install Help
    Jul 2013
    Puerto Rico
    76
    Hi!
    I'm installing a new SWG (Hayward).
    Have been reading up on the manuals and they indicate preparing the water. For salt system they recommend getting the salt and stabilizer to level as well as use metal reducer.
    What are the experiences in the real world?
    Thanks!
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Balancing Water Before SWG Install Help
    Have you looked at this pool-school/salt_water_chlorine_generators.
    Do have one of the test kits we recommend ?
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Do you even have any metals that need reducing? Other than that, balance the pool per pool school, especially cya level required for your SWG and add the salt and circulate for 24 hours prior.
    Jul 2013
    Puerto Rico
    76
    I'll need to test for metals.
    Thanks for the help!
    Jul 2013
    Puerto Rico
    76
    Hi!
    Ok, I just tested the water with Pentair Model 78 All-In-One Kit
    Pool is 6,500gal
    Chlorine Residual: Right at 1ppm
    pH: 7.3ppm
    Acid Demand: Did not test as kit states if pH is above 7.8ppm
    Total Alkalinity: 30ppm
    Metals: I will have to take a sample to the store or can anyone recommend an available kit?
    How does it look?
    Thanks in advance.
    J
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Your TA is low and needs to come up. With that low TA, your pH is susceptible to wild pH swings. 60-80 would be much better for a SWG pool.
    Essential Links:
    Jun 2011
    Long Beach, CA
    2,790
    You need to add your pool specs in your signature and we can offer more precise answers. The ranges you need depend on your pool type; plaster, vinyl, fiberglass.
    You need to adjust your TA up to 60-80 range, use baking soda for this. Use the pool calculator for the amount you need to add, http://www.poolcalculator.com/.
    If you want to have full control of your pool you will need a test kit that we recommend. The kit you have seems to be missing a couple of the tests. See my signature for the link to the test kits.
    Read Pool School, top right button on each page, it will be in your best interest to understanding your pool.
    Chlorine is low but it all depends on your CYA level. With a SWG you want the CYA to be 70-80.
    I would not be too worried about metals in the water to get the SWG up and running. If you are on well water to fill the pool then I suggest you to get the water tested for metals. Most pool stores should be able to test this for you. If you added something with copper in it to the water, then you will want to test for metals.
    Jul 2013
    Puerto Rico
    76
    Thanks so much for the valuable comments!
    I do agree about the TA.
    The pool is plaster and I will be getting the SWG system in in about 2 weeks (ordered it this morning).
    I did put copper-based algaecide about 4 years ago.
    Jul 2013
    Puerto Rico
    76
    By the way, I am in Puerto Rico so pool supplies here are quite limited and expensive.
    I will check on the best pool store we have, see what test kits they carry and come back for opinions (if I don't find the ones already suggested).
    Thanks!
    38,371
    Please add your pool details to your signature and location to your profile as described HERE as it will help us help you ... like that tidbit about being in Puerto Rico
    Since the pool supplies are expensive ... all the more reason to see if you can find the equivalent in the laundry aisle (bleach, etc) or hardware store (muriatic acid).
    Jul 2013
    Puerto Rico
    76
    Ok,
    I just added the info to my signature and am testing with this post.
    38,371
    Now please limit the length of the signature to 5 lines maximum as stated in the forum rules. Also put your location in the profile instead of the signature.
    Jul 2013
    Puerto Rico
    76
    Much better now!
    Well, it is nice down here, but the heat is diabolical from July-September.
    I don't mind paying the price as long as it is the correct stuff.
    I do have access to shipping to Florida and have the items sent to me (when dealing with companies that do not ship direct to PR).
    My new SWG system should be here late next week and I want to start preparing in order to have the pool properly balanced and ready for the salt.
    Thanks!
    J
    Jun 2011
    Long Beach, CA
    2,790
    You can put the salt in now so you will not have to wait for it to mix in later. Make sure you measure the salt content before you add any salt to the water as it already has some in it, but how much you will not know until it gets tested. Find a manual online to see how much salt the SWG requires.
    Do you know if there are metals in your supply water? The algaecide 4 years ago should not be of any concern now.
    Jul 2013
    Puerto Rico
    76
    Thanks for all the input!
    I will check today if I can get a better Test Kit (hopefully one of the kits mentioned here). I will also Test my Tap Water as the pool gets filled with that and rain.
    Will post results here.
    Thanks!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you have a Zip Code, Dave can send you a kit. Just make sure your salt has no additives like resin cleaner or Iron cleaner. I don't know the demand for softener salt down there or how hard it will be to find. Good luck and post back for an update with the new kit.
    Essential Links:
    Jul 2013
    Puerto Rico
    76
    Hi!
    Ok, the closest I could find was the K-2005 so I purchased as it should not be too far from the K-2006 (I hope).
    I must say this Taylor Kit looks WAY more complete and professional than anything I've seen before.
    Ran tap water for a minute and took a 1 cup sample.
    Tap Water Results (San Juan, PR):
    Free Chlorine = 1.5ppm
    Total Chlorine = 2.0ppm
    Combined Chlorine = 0.5ppm
    Total Bromine = 3ppm
    PH = 8.0
    Alkalinity Test = 110ppm Calcium Carbonate
    Calcium Hardness = 70ppm Calcium Carbonate
    I am currently waiting on the Pool to be running for about 1 hour to take the sample and test the Pool Water.
    Will post as soon as done.
    Thanks!
    J
    38,371
    Bad news. The K-2005 is not what you want. You need to add the FAS-DPD chlorine test to your kit to have the equivalent of the K-2006 ... and that just happens to be the most expensive test.
    Jul 2013
    Puerto Rico
    76
    Oh Man!
    Can it be obtained separately?
  20. Back To Top    #20
    38,371
    Sure.
    Dave sells it: http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html or I think you can find it on Amazon.
