Results 1 to 19 of 19
Thread: Two day old coping and it is cracking already
    Should we worry about these cracks on the faces of the coping when control joints are only on top? We have about ten cracks so far which represents roughly 40 percent of the coping control joints. Can this be repaired or is it an issue with how they mixed concrete? Will there be bigger problems down the road? Seems like they will only get allot worse. Also coping color doesn't match decking.
    Apr 2013
    Central Massachusetts
    174
    Re: Two day old coping and it is cracking already
    I know those types of cracks are common with cantilever coping but 2 days does seem a little soon. I'm having mine poured next week. I'll let you know if I experience the same thing.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Were you on site when the concrete was poured? If you were, how wet or dry was the mix? If very wet, almost soup-like, you can expect many microcracks. When it was poured, would the concrete "stack up" as it came out of the chute or did it "flow" a long distance?
    When pouring concrete, it is best to wet it only as much as you need for workability. It takes more effort to work a dry mix, but the results are worth it. Wet mixes also tend to have color variations between pours, even with the same mix of concrete/coloring agent. Using a vibrator on dry mixes helps with the smoothing process, and removes any air bubbles in the finish.
    The cracks you picture may not actually be any deeper than 1/4 - 1/2", but could be deeper. I'd be asking you PB about replacement. You will have a hard time keeping the coping sealed.
    Charlie, unfortunately I did not witness the pour, I wondering if they did replace coping how they would get it out with damaging the integrity of the pool, ie jackhammers or sledgehammers
    Mass nerd, I am looking forward to seeing your pool pics
    Apr 2013
    NJ
    57
    My brother-in-law had his cantilever crack within first month in same spot. PB came out and cut the expansion joint down around the curve and it solved the problem. All the hair line cracks were at the expansion joint above on the deck.
    24,000 gallon vinyl, 2 main drains, 2 skimmers, 4 returns, 2 inch pipe suction, 1.5 inch return. Pentair VS pump, Pentair IC-40 SWG, Pentair SD-80 filter. TF-100.
    sdspencer's Avatar
    Apr 2013
    Temecula, CA
    42
    Is there a reason why the control joints are only on the top? My cantilever coping has it going down the edges. My coping was poured almost 2 months ago and I don't see any cracking as of yet. Then again it's hard to tell because ours is also stamped (mistake by the concrete guys ) but those cracks would bother me as well.
    Approx. 16k gal (16.5' x 30.5') Freeform, Salt Water, Stonescapes Tahoe Blue Mini Pebble, Intelliflo Variable Speed Pump, Hayward Shark Vac Cleaning Robot
    ColdAirGuy's Avatar
    California
    85
    My Pour in place coping was done a few months ago but the control joints go around the curve. I still have "micro cracks" here and there like yours.
    Like you, I was at work when they did the coping so didn't witness their method.
    Anthony 16,000 Gallon Oval, White plaster, 30' Long 15' Wide 5 1/2' Deep end 3 1/2' shallow end.
    Pentair Intelliflo, FNS Plus 60sf. DE, Pentair Intellibrite 5G
    TF100 Testkit
    May 2013
    Central Texas
    42
    There is no such thing as crack free concrete - if there was, I would be rich.. It cracked at the weak point and I agree with others that the control joint should have been extended, but then you would only have a crack at that area.
    +/-16k gallon IG pebblesheen pool with SWG, spa and waterfall, Hayward 2HP 2-speed Tri-star, Hayward 1.5HP Tri-star, Hayward 5030 Cartridge filter, Hayward H400 Heater, Sharkvac Robotic Cleaner
    What is the best solution?
    1. Leave cracks and ask for discount? (How much?)
    2. Cut control joints with a diamond blade? ( possible risk of coping crumbling because cracks are not straight)
    3. Tear out and redo on PB dollar?
    4. ??
    Jun 2012
    western NY
    1,560
    Quote Originally Posted by Lmiso
    Any concrete work I have ever done for people comes with this disclaimer...I can guarantee two things will happen. Concrete will get hard and it will crack. The only thing I see"wrong" here is that they did not extend the joint around the edge of the coping. If you look you will see that the crack extends all the way thru the beauty joint already. I don't know if there is much you can ask for. With or without the beauty joint the cracks would have developed at some time.
    You could do this, but the control joint is already established now. It is posible to take a small grinder and feather the edges to prevent any chipping. your PB may agree to this. The cracks appeared due to one thing. Shrinkage induced stress. When water evaporated out of the mix the edges tend to shrink some putting stress on the mass. Eventually the stress has to relieve and since concrete is a horible material when in tension, cracks happen. This is why it is important to seal the concrete as soon as posible after the pour to prevent the water evaporation.
    All I can say here is "good Luck"
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    May 2013
    Central Texas
    42
    4. ??
    What ever you do, do not patch it. The good news is that your concrete is "normal"
    If you look at control joints (everywhere) sidewalks, etc, that is where they are normally cracked - they are there for that reason.
    I would discuss a cosmetic solution to the portion that they did not install correctly. As noted by others, any grinding may cause it to spall more and make look worse.
    Quote Originally Posted by danpik
    ...The cracks appeared due to one thing. Shrinkage induced stress. When water evaporated out of the mix the edges tend to shrink some putting stress on the mass. Eventually the stress has to relieve and since concrete is a horible material when in tension, cracks happen. This is why it is important to seal the concrete as soon as posible after the pour to prevent the water evaporation...
    Would you please explain what "sealing the concrete" means?
    I been told to try to keep the exposed concrete surfaces moist with water over the first 72 hours, to reduce the rate of evaporation and to remove heat generated in the curing process.
    18,000 Gallon IG, Pebble Sheen, Quartzite coping
    Pentair 420 Cartridge Filter, 2HP Silencer, 400,000 BTU Heater, Platinum Legend Cleaner
    2x IntelliFlo VS pumps - Screenlogic Interface - Stenner 45MPHP10 15 Gal Bleach Injection
    TF100 + PoolCalculator + This Site!
    May 2013
    Central Texas
    42
    Quote Originally Posted by ignoramous
    From a design perspective, concrete is a porous product (sand, rock, cement, and water) and regardless what you do, it will crack. You can apply what ever seal you want and it will crack later. The goal is to attempt to mitigate the cracks and migration of water so that you do not structurally damage the substrate (e.g. erosion) and for the purposes of pools - loose water. Assuming they used a water proof "mortar" under the coping, the latter is unlikely. My opinion, you are dealing with a cosmetic item. These types of items tend to have a worse fix, then negotiations or other remedies previously outlined.
    Disclaimer: I am not a pool builder or concrete installer, but I have dealt with the latter and owners way too long.
    Jun 2012
    western NY
    1,560
    [quote="ignoramous
    I been told to try to keep the exposed concrete surfaces moist with water over the first 72 hours, to reduce the rate of evaporation and to remove heat generated in the curing process.[/quote]
    Concrete cures by a chemical reaction. This "exothermic" reaction produces heat to cure the elements of the mix into one solid mass. Concrete does not "dry" as it is often refered to. all of the water that was added to the mix at the plant should be present in the mix when cured. If water evaporates out of the mix during this cure process then the strength of the mix is diminished somewhat. also, any evaporation causes loss of mass in the area it evaporates from which causes shrinkage, which induces stress. Most concrete installers recomend keeping the pour wet as yours did. This will, as they said, keep the evaporation in check. However, if the surface dries out, the wetting process may as well be over.
    When we pour concrete, we put a concrete sealer on it as soon as the "sheen" is gone. That sheen is the excess water that has migrated to the surface during the finishing. Usually less than an hour after we have done the last of the finishing is when we spray the sealer. This forms a waterproof membrane on the surface that stops all evaporation. I have done driveways for people that stayed green for up to two weeks when doing this. I routinly have to explain to the customer that this is normal for my jobs and it will, over a 2-3 week period, slowly turn to the light grey the are accustomed to seeing.
    The apron of my driveway and my neighbors driveway are a good studdy in why proper curing is essential for concrete. I did my apron about 10 years ago. and it is still in excellent condition. This, mind you, is in an area where the roads are paved in rock salt all winter. My neighbors driveway, done a couple years later, is all spalled on the surface and is full of cracks. The idiot contractor told him not to waste any money on a sealer and just let it dry out. This caused a lot of surface evaporation which weakened the surface layer. (I also suspect they did not finish it properly and just did a quick float and broom job on it) They also did not put in any control joints in a timely manner. Instead, they cut them in almost a month later. Look at it now and there is not one crack in the control joints but there are several throuout the surface of the drive.
    PB came out and starting cutting control joints in the lip of the coping, sure as sh&t it starting crumbling. He said this is how he always does it and it just has to be patched now. I am very skeptical.
    Here are some new pics of the repair job, crumbling and cracks that seem to be growing after a week
    danpik:
    Thanks for the explanation about sealing concrete. That's the first I've heard of using a sealer during curing to limit evaporation.
    My PB wants to use Sundek to fill in cracks and seal coping, any thoughts?
    Feb 2013
    Melbourne, Australia
    102
    There is a different between sealer and curing compound. Curing agents are applied while the concrete is uncured, to retain moisture and prevent the surface dehydrating and therefore hardening faster than the underlying concrete, which causes cracking. One of the common ones is a latex based liquid which seals the surface temporarily, breaks down in UV light and disappears in a few days. Sealer is applied at least several days, if not weeks, after the concrete is poured, and is used to enhance the appearance of the concrete, prevent staining and to try to keep the colour as uniform as possible under wear and tear.
    As for the cracks, they have occurred exactly where they were intended and as others have said, the tooled joint probably should have extended around the lip. In saying that, the crack would still occur so there is no structural or functional failure, purely aesthetic, and even then minor. I doubt it will get any worse, and I think you'll find in time you will barely notice them.
    Where they have saw cut, did they use a continuous rim blade, or a segmented blade? Continuous rim will cause a lot less spalling along the cut. If you really need it fixed, it could be caulked with a coloured urethane caulk.
    FWIW, I am a structural foreman with a concrete/formwork company in Australia.
    41k litre (11k gal) shotcrete in ground pool, Hayward super 2, Davey Monarch 28, zodiac SWCG
    - undergoing a transformation!
    2nd season Pool Owner. TF-100 testing
    Melbourne, Australia.
