Results 1 to 7 of 7
Thread: Good Deal or Not Good Deal
    Jul 2013
    Santa Fe, Texas
    15
    Ran across this today, I can get it all for $1.00 a gallon What are your thoughts? Not sure if it is really old but it is dirty!
    Eugene, New Pool Noobie
    Intex 12' x 24' x 52" AG 1600 gph Sand pump Krystal Klear,8400 Gallons
    Installed 7/27/13 TF-100 On order "Freshman in Pool School"
    Jun 2012
    Howell, NJ
    977
    Re: Good Deal or Not Good Deal
    That stuff looks like it has been sitting there a long time. What strength is it supposed to be?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jul 2013
    Santa Fe, Texas
    15
    10%.....actually there are pigeons nest above so they got pretty dirty from that.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    I don't know who blends the Smart brand but most of the time it's regional. Most in your area is made in Dallas and might have a date code on the box and bottle like. 13 215 1300 B1 TX1... First two is year, second set is day of year, 24hour time, blending bottling line. If it has the same type of code look at the date. I would say 155 and up might be 10 or close. Older than that it would be less than 10%. Still useable but at first you would have to test, then dose, then test. If you used 10% and did not hit your target just plug your first test in now and your new test in target and start changing the % til you match the dose amount. Then you will have a good idea of the strength.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would look for a code date, liquid chlorine does not age well, if over 6 months old forget it, particularly stored outdoors in Texas in the Summer.
    Jun 2013
    Central Texas
    9
    I bought a case of this at a Home Depot in central Texas last month, and it was very weak.
    15.5K gal, IG vinyl, Hayward 1/2 HP, AquaView 3.14 sq ft sand filter (above ground pool installed in ground, so no main drain), TF-100 test kit w/SpeedStir, BBB, Liquidator.
    Jul 2013
    Santa Fe, Texas
    15
    Thanks.....it us at a home depot and old
