Results 1 to 13 of 13
Thread: Disolved CYA and shutting off pump
    Jun 2011
    Central Iowa
    105
    Hello all! Day 2 complete of our new pool and BBB method is coming along nice. I just dissolved 24oz of stabilizer in a sock in the skimmer basket. All was dissolved and sock empty after some squishing around in about 3-4 hours. Can I turn the pump off for the night or should I let it run all night? It's been running all day so thought I would give her a break.
    Thanks!
    27' x 54" AG Morada RTR/19,300 gal/ 1hp-2spd Hayward Power-Flo Matrix/Hayward 256T sand filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Disolved CYA and shutting off pump
    You should let run for 24hrs to help dissolve. I do it that way. Won't hurt a thing.
    Jeff
    30,432
    Since the CYA is dissolved, turning it off is fine.
    Jun 2011
    Central Iowa
    105
    Will do, thanks for the prompt reply!!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    As for testing the CYA , I would still wait another 5-7 days. If you test too early, there's a risk that you may get a lower reading and you might be tempted to add more causing you to overshoot your target. CYA is one of those things that is much easier to add/increase than it is to lower.
    Jun 2011
    Central Iowa
    105
    Thanks, I added 48 oz of stabilizer which should bring me to 21. I'm thinking I will need another lb but wanted to wait a week and test to become confident in my testing and calculations. As you mentioned I would rather be a bit short and add a little more than overshoot and be at a level higher than I wanted.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    21 ppm is a bit low, unless you already have some CYA level.
    Should be 30-50 ppm.
    Jeff
    Jun 2011
    Central Iowa
    105
    Ok, maybe I'll just put the last LB in tomorrow and give it a week. I should be closer to 30 than 20 at that point.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If your pool gets alot of sun 8-10 hrs 40 ppm will work pretty good. That's where mine is.
    Jeff
    Jun 2011
    Central Iowa
    105
    It's full sun but we keep it covered a lot to try and warm it up.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I take it you have a solar cover. With a really sunny hot day leave the cover off. You'll get better heating that way. The cover is good at keeping the temp in the water at night so you don't get heat loss due to evaporation.
    I've already taken my cover off in the morning before the sun comes up and had steam coming off the water. Air temp was lower than pool water.
    Jeff
    Jun 2011
    Central Iowa
    105
    I did that Thursday, high of 82 but left it on today 85. It's pretty hard for me to get it on and off weekdays by myself...ok dang near impossible! It's been so cool here the past couple weeks for July, high 70's low 80's. Just when I get my pool fill mother nature decides it's September! They have high's in the 70's for next weekend too. I guess it's better than rain.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I hear ya. It's the same here also. Next week no better. The kids were in today. Water temp was 84. Rain tomorrow. It's been a weird summer here.
    Jeff
