Thread: Help gray pool
    Help gray pool
    My pool is gray, I killed the algae but?
    18'x36' In ground pool - roughly 25,000 gallons; Sand filter; Vinyl liner;
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Help gray pool
    ...you need a lot more time to filter it out.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Help gray pool
    Welcome to TFP !
    Your done when
    1 water is clear.
    2 CC of 0.5 or less.
    3 you pass the OCLT.
    Jeff
    Re: Help gray pool
    Most dead algae is grey. If you have grey cloudy water with a greenish tint, you still have algae alive in there. What kind of filter do you have (DE, cartridge, sand)?
    In any case, continue SLAMming it until you meet all 3 criteria pwrstrk posted to make sure the algae stays gone.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Help gray pool
    Welcome to the forum computhan. These guys have you covered, and you just have a way to go yet. It takes time to clear a bloom of Algae, but if you stay with it things will come around. When you come back to answer, please take a minute to fill in some pool info and location in your signature line. All the info helps us help you a lot better.
    Essential Links:
