Results 1 to 11 of 11
Thread: Pool drain question
    Jun 2013
    Northern NJ
    123
    Pool drain question
    So from previous questions we have determined that due to my very high CYA levels, I will have to drain a substantial ammount of water. Can I do this at the end if the season and let it sit all winter ? My pool is covered all winter and is vinyl. Thanks
    36,000 gal IG vinyl. Haywood pump and heater Hayward DE filter blue diamond robot. Hayward Aqua Rite SWG AQR-15
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Pool drain question
    I don't think you would want to do that with a vinyl liner. It would damage it. You can't drain and fill it back up ?
    Jeff
    Jun 2013
    Northern NJ
    123
    I could. I suppose it would take the better part of a day or so to drain a few feet out. I'm not sure how to determine how much water to drain. I have 39,200 gallons and my CYA was about 140
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Use the pool calc http://www.poolcalculator.com/. It will tell you. Enter your current CYA and then enter where you want it to be and hit calc.
    What test kit do you have !
    Jeff
    Jun 2013
    Northern NJ
    123
    I have the Taylor tf 100
    Jun 2013
    Northern NJ
    123
    Calculator says I need to drain 43%
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Ok just wanted to make sure we have a good test kit, so your current CYA level is valid. Good job !
    Jeff
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by Thesil
    There you go.
    Jeff
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You can drain in thirds. Take a test and see where you are.
    I would t drain all at once.
    Jeff
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Your test kit only tests up to 100 ppm
    Jeff
    Jun 2013
    Northern NJ
    123
    Yeah but I used half pool water and half tap water and multiplied the answer by 2 to get 140. I will drain at end if season, then fill it up and cover for the winter. Sound good?
