Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Thread: Have lagoon, seeking Creature
    This year for the first time I can't get pool to blue. Pool store tests say chemicals fine, replaced sand in filter, had pool guy out for consult. Everyone mystified. Running filter about 20 hours a day.
    Grace Suarez
    You Bet, California
    10k gal AG vinyl, Hayward sand filter
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Have lagoon, seeking Creature
    Time to buy a REAL test kit of your own. See my siggy to find the link to them.
    It can be done and for cheaper than you every thought!
    Kim
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Please post a full set of test results including FC, CC, ph, TA, CH, cya.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    30,431
    Very good!
    Every water quality issue we address here begins and ends with accurate testing.
    Since you don't yet do your own testing, do you have available the most recent test results taken?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    I nominate Richard for the creature!
    Yep, those pool test results must be right on the money! As soon as they told me that, I'd have showed them a pic and said, "Really"?
    Thank you. I will get another test and go in with the photo.
    Grace Suarez
    You Bet, California
    Latest test results
    Total and free chlorine 1.8
    Ph 7.7
    Alkalinity 120
    Calcium 275
    Stabilizer 120
    Phosphate 1000
    Grace Suarez
    You Bet, California
    38,474
    And .... Still unreliable pool store test results.
    If true, your CYA is way too high and your FC is way too low. Have you read the ABCs article at the top of Pool School?
    Donldson's Avatar
    NW Ohio
    2,916
    Just today someone found out that while the pool store said his CYA was 155, once he did his own test (after working hard to reduce it) it turned out it was closer to 30 and he didn't need to do anything. Much more often we have found pool store CYA tests to be way lower than actual. It's to the point where I won't give advice based on pool store results.
    Bottom line: Pool Store test results aren't worth a wooden nickel. If you want something done right, get your own test kit.
    And I am going to resist saying some not-nice things about the pool store employees. Suffice to say that they say your FC is less than 2 and your CYA is more than 100, and they are mystified that you have a green pool?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Chemistry not being my strength, can y'all recommend a test kit that is fairly simple? I have the kind that measures chlorine and Ph.
    Grace Suarez
    You Bet, California
    Jun 2012
    Howell, NJ
    977
    Either the K-2006 or TF-100, the TF-100 being the better value. Since you live in California, you may be better ordering from poolsupplyworld.vom
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jan 2013
    Houston, TX
    1,079
    The TF-100 it will walk you thru. CYA test isn't reliable over 100 in any event and I bet you a cold frosty one the pool store didnt dilute then do the test to get a proper result. CYA could be north of 200.
    Do yourself a HUGE favor. Stay away from the pool store and order a TF-100. We will walk you through the rest.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Thank you. Will shop for TF-100
    Grace Suarez
    You Bet, California
    My local pool store doesn't have the TF-100. Where's a good place to order it from?
    Grace Suarez
    You Bet, California
    Jun 2012
    Howell, NJ
    977
    Since you are in California, Pool Supply World is probably where you should order it from.
    John
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Yep......get the TF-100 would be my advice as well. Yes....it is an expense up front but you will save so much in the long run. Pool chemistry is not rocket science as I've learned here. Follow the directions and listen to advice here and you won't be blindly buying what the pool store wants to sell you. You might not get it all on day one or two but if you test your own water and read pool school you WILL "get it" and then? You will be in control of your own sparkling pool. I promise.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Done! Thank you. I'll be back!
    Grace Suarez
    You Bet, California
    Look in Donaldson's signature lines and click on where he has "test kits." Order the TF100 extra large option since it is clear you will be SLAMming the pool and thus needing more volume of the reagents than for clear pool maintenance. Getting your own reliable test kit and investing the time to read here will serve you very well and you will be amazed at the results. Going through the SLAM process is nobody's wish, but by the end of it you will have a great understanding of how to test, why to test, and what to do with the test results. That knowledge, a great test kit, and a trip to the grocery store for chemicals is all that is needed to get and then keep a sparkly clear pool. Congrats on making the decision to stick around! Post back with questions as needed - we love seeing these success stories in action, especially with photos!!
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
  20. Back To Top    #20
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    If you travel to Rocklin in your commute, they have the TF-100 in stock.
    -- Guy --
