Thread: Back flush water for garden?
    I do not have to back flush very often, but what do you guys think about recycling back flush water for my garden? I have a few rain barrels that are hooked up to the gutters, but sometimes run dry due to lack of rain. Any concerns from pool chemicals hurting the veggies or the people that eat them?
    21.5K gal, vinyl, ?? HP Jacuzzi pump, sand filter
    22,548
    Re: Back flush water for garden?
    If you pump it into a rain barrel the chlorine will be gone quickly and as long as you follow the BBB method and don't use flocculent, algaecide, pool store magic stuff, you'll be fine to use it.
    Bama - Interesting concept...I get the CL deterioration - are you suggesting the other chemicals (CYA, Borax, salt content, etc.) are not harmful for use as garden water? This could be a really great way to recycle my backwash (although this year wouldn't have needed it). Thanks in advance.
    Best,
    Sciz
    Completed March 1, 2013. 12,500 gallon IG Lagoon Style w/swimout, walk-in steps, 15' x 30' x 3' - 5', Gunite, Wet Edge Technologies, Pebble Sheen - Northshore Tahoe, 2" Tennessee Fieldstone Coping, Belgard Country Blend Pavers, 1.5 HP Superflo, 19" Tagelus Filter, IC-20 SWCG.
    Donldson's Avatar
    NW Ohio
    2,893
    The other chemicals are really trace amounts, except for salt in an SWG pool. I might not use SWG water, and I wouldn't exclusively use pool water, but pool water should be just fine. Once you take out the chlorine algae sure likes it!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    22,548
    The CYA will be fine and borax is a natural mineral so is salt as long as it's not terribly high.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    I don't use pool water on my vegetables, but the lawn and the flowers don't seem bothered by it.
