Thread: Solved the low salt light vs. test results
    Aug 2011
    Augusta, Kansas
    88
    I thought I'd share my discovery/solution. My Intex SWG (Mr. G) started flashing the low salt light. At first my test results agreed and I added the needed amount of salt. I sent the kids into play to "stir the tea" as we call it. The remainer of the week Mr. G continued with the low salt beeping. My test results indicated that I was fine - maybe a smidge towards the low end of the scale but nothing close to the beeping end of the scale.
    I decided to give Mr.G a good cleaning thinking maybe some build up on the plates was causing the missleading reading. I pulled Mr. G from the filter and filled the tube with vinegar. I let him soak all day. I did notice some buildup so I crossed my fingers. At 10 pm in semi-darkness (yes I'd forgotten about him) I hosed out the vinegar and reattached everything and started the system back up No code!
    So if your SWG is throwing a low salt and you know your salt level is fine....it may be time to give your SWG a good vinegar soak.
    Diane
    Diane
    15,000 salty gallons - 24' x 12' x 52" Intex Ultra Frame Pool
    Intex Sand Filter, Pump, SWG - TF-100 and speed stir
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Solved the low salt light vs. test results
    If you post a full set of test results, especially ph, CH, TA, cya, salt and borate level (if you use it) and we may be able to help reduce the occurrence of deposits.
