Thread: First Time Test
    Jul 2013
    Grand Rapids, Michigan
    55
    First Time Test
    Just received and used my TF-100 test kit last night. CYA was low at 30 and cholorine was low at 1-2. I'm a little confused about free chlorine though. How to I figure out what that is again?
    23,200 gallon in ground pool, Vinyl Liner, Salt Water, Variable Speed Pump Intelliflow 3hp/1.32SF/3.96 SFHP, Filter Pentair FNS PLus DE FNSP36, Heater Pentair Mastertemp 250, SWG Jandy APURE35PLG, TF-100 Test Kit
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: First Time Test
    Your initial test with the DPD powder (R-0870) and titrating agent (R-0871) five you your FC. You then add the R-0003 and if the color of the sample changes back to even the slightest pink, you count drops of R-0871 to turn it clear again. This gives you your CC.
    Your FC is your Free Chlorine, Use http://www.poolcalculator.com to find out how much bleach to add to bring it up to 4-6 ppm. Retest in an hour to ensure you have reached your target.
    Jul 2013
    55
    Re: First Time Test
    Thank you. I'll read through that again tonight.
