Thread: Rusted Bottom Straps
    I have just acquired a 16'x32' above ground pool. We just disassembled and found that the steel straps on the bottom were rusted and broken. Where can i get replacements for these? I was wondering if I could just use treated lumber for ground contact, nylon strapping, or steel cable in place of these.
    What do you think?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Rusted Bottom Straps
    Welcome to tfp, causeofhim
    My first reaction is that the pool is not worth installing. What shape is the rest of it?
    I may be wrong though...do you know the brand/model of the pool?
    One thought is to install the pool just like one would install an oval with a deep end. When installed like that, I think the straps are not used. When using that approach, I don't think it is necessary to actually do a deep end (though I would recommend it).
    A couple of the side supports are bent, an easy fix, but the rest of the pool is in great shape. How do I install with out bottom straps?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    This is a site that has some information on it and links to more: http://www.shadebuilder.com/Above-Gr...irections.html
