Thread: compupool command module overheating
    Honolulu, Hawaii
    26
    Recently had problems with module's time being thrown off several times a week. After a while, realized it was overheating (saw it happen) and turning off and messing up the time. I cut back % from 60 to 40 and it is still overheating. Any ideas?
    pH 8
    FC 4
    CC 0.5
    TA 110
    CH 400
    Cya 40
    Salt 3330
    I now have a CIrcupool RJ60
    10,500 gal; Hayward S244T sand filter GPM/FT 20; Intelliflo Vairiable Speed pump; 3/4 hp PAC FAB Challenger pump; IG; plaster ; CircuPool RJ60 SWG; Polaris 280 pool sweep
    Honolulu, Hawaii
    26
    Re: compupool command module overheating
    also a intelliflo variable pump
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Call tech support .. It should not do that.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Honolulu, Hawaii
    26
    Thanks.That's what I was thinking. I emailed them since they're closed today and I will call on Monday. I turned it off and will use chlorox as it was getting worse.
