Results 1 to 8 of 8
Thread: TF-100 first test!
    Jul 2013
    St. Louis, MO
    16
    TF-100 first test!
    Well the numbers are in..... I know I know "Go to pool school and use the pool calculator" Well I did and I just dont know if I tackle all problems at the same time or 1 at a time? Any advice would be great! BTW this is a brand new AGP that I put all of the starter conditioner I had in it 2 nights ago. Anyways, here are the results...
    FC 0
    TC 0
    CC 0 ( I know, obviously right?)
    TA 90
    CH 140
    CYA 0
    PH 7.8 - 8?
    I have my pencils and notebook ready! Time for class
    30' 22k Gallons
    ECCO 1.5 hp 19" sand filter w/ aqua smart filtration system
    AGP
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: TF-100 first test!
    I would start with some clorine !!!
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Jun 2012
    Howell, NJ
    977
    How much starter conditioner did you add? First, you should add chlorine in there to the recommended level based on how much CYA you added. Then I would lower the pH to around 7.2.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    30,431
    Welcome to the forum.
    What does your water look like?
    Jul 2013
    St. Louis, MO
    16
    well water looks great.... maybe a green tint to it? IDK hard to tell with the green/blue liner. And for the chlorine, I am not going with my chlorine cartridges, instead I want to follow the BBB method. In that case "chlorine" is really "bleach" right?
    30' 22k Gallons
    AGP
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Maybe a green tint ? With no chlorine you need to SLAM. Read the process in pool school and follow to a T. If you do the OCLT pool-school/overnight_fc_test that will tell if something is consuming your chlorine. Yes bleach is chlorine. That's what you'll slam with.
    Jeff
    30,431
    jfoeller,
    Let's go a little slower here. A new fill often does not require slamming, but we need some more info.
    I don't know what "starter conditioner" is so tell us what and how much you have put in your pool so far. Have you added any chlorine yet? Is the fill water from a well?
    Smykowski's Avatar
    Sep 2011
    3,065
    Let's go back to this question as well. Is the green tint you're talking about looking like someone put a little green food coloring in and it's otherwise crystal clear? Or is it a green tint with a little haze to it, like it wants to turn a little milky and cloudy?
