Thread: Closing pool in Richmond, Va?
    May 2013
    Virginia
    75
    Thinking ahead here...
    I'm wondering if I need to close the pool? Blow out the drains and all that mysterious stuff? We do get below freezing just a handful of nights in Jan/Feb (sometimes as low as the teens), but generally the winter is mild. It's uncommon to be below freezing during the day. In fact, a lot of times in January we get days that get pretty warm - 60's and maybe even 70.
    eta - if it does freeze, only the top inch or so at the most would freeze over. At our old house we had a goldfish barrel (maybe two feet tall by two feet diameter), and the the top 3 inches or so would freeze some nights (not very often), but it never froze all the way through. Also, the pump and all the pipes are located in a shed built into a hill. Our pool is built into a hill and all the plumbing goes down through the hill into the pump house.
    I'm really hoping I don't have to mess with closing a pool, but I will to avoid expensive repairs in the spring.
    10,000 gallon inground, gunite, 500lb sand filter. Brand new to this pool thing.
    Jun 2013
    SpringHill FL
    415
    Re: Closing pool in Richmond, Va?
    Just a suggestion but look at intermatic website they have a thermoswitch adjustable from 45-32 deg it will turn your pump on and circulate the water to avoid freezing. This maybe an option for you
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    May 2013
    Fort Lauderdale, FL
    423
    I would winterize. Just because we've had a few mild winters doesn't meet we won't get a hard freeze this year. The frost line is 18" for most building codes around here. All your above ground pipes, filter, and pump could potentially freeze and break.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
