Thread: leaking waste pipe
    WNY
    35
    leaking waste pipe
    My waste pipe is leaking from the top. I have tried opening and closing the valve but it won't stop leaking. Is there some way I can fix that myself? I just had the pool co. here last night to fix my leaking pump and the connection of the waste pipe to the pump. I had to wait 3 weeks for them to get here so if I can do it myself I'd rather. I have a Jacuzzi Magnum
    Force pump and cartridge filter if that helps.
    Thanks.
    23000 gal. 18 x 36 IG vinyl
    Jacuzzi Magnum Force 1.5 hp. pump
    Jacuzzi CFR 100 cartridge filter
    AutoPilot Digital 220 SWG
    LaarsLite 250 gas heater
    Re: leaking waste pipe
    Quote Originally Posted by poolbee
    Thanks.
    If you can add a picture of your system and show where it's leaking that would be a great help.
