Thread: First sign of algae....
    Mar 2013
    CT
    351
    I have had my pool open all Summer and haven't had any issues what so ever. I follow the BBB method to a "T" and everything has been great. Last night I noticed just a small amount of green growing on the walls and floor of my pool in several different spots. First time ever. It brushed right off very easily. It was definitely greenish in color. After brushing, I gave the entire pool a good vacuum. The water was and is still crystal clear. But this has me a little concerned because I haven't seen this situation at all with my pool the entire time it has been open all year.
    The only thing I have been doing different is that I recently raised the CYA up slightly. It was at about 30. It's now at roughly 45/50. I was still targeting 5 ppm for chlorine even with the new CYA reading. Should I raise my chlorine target up to 6 ppm or possibly higher given the new CYA reading and recent algae issue and just leave maintain that target the rest of the Summer to prevent any further outbreaks?
    Last nights test results were as follows.
    FC - 2.5
    pH - 7.4
    TA - 50
    CYA - Between 40 and 50
    CC - 0
    I'm thinking the FC at 2.5 might have been a little low given my new CYA reading and perhaps that's what allowed the algae to begin to grow.
    Pool calculator told me to add 111 oz of bleach but I put in a full gallon (128 oz) because I was a little (to say the least) paranoid when I saw the green slime on my pool walls.
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: First sign of algae....
    For a CYA of 50 you want your FC levels to be 4-8. Don't let it drop below 4. Take an OCLT test to make sure nothing is consuming your chlorine. pool-school/overnight_fc_test
    Is your water clear ? What test kit are you using ?
    Jeff
    Mar 2013
    CT
    351
    Quote Originally Posted by pwrstrk
    Is your water clear. What test kit are you using
    Sent from my iPhone using Tapatalk.
    So my new target should be 6 then??
    Yes - Water is crystal clear. No issues at all with water clarity.
    Taylor K-20006 test kit (see sig.)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If your losing more than 2 ppm due to the sun take it up to 7-8. That will give you some breathing room so you don't fall out of range.
    Jeff
    Jun 2012
    Howell, NJ
    977
    If you can see algae, you need to SLAM the pool. Link in my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
