Ok i am new here and new to owning a pool which came with the house I purchased. Bought the TF-100 kit and went to testing. First test was chlorine. Added one scoop to 10ml and water didn't even turn pink. So I guess I have no chlorine in the pool. Next tested TA. After adding R-0007 mixing, then add 5 drops of R-0008 the water turned pink instead of green. What does this mean? Finally I tested CYA and it came out around 100. I justed moved in and previous owner used only chlorine tabs and also took water sample to pool store once in a while to have them tell him what was needed. Am I right in assuming i am going to have to do a partial drain and fill to get this back on track? Numbers seem way off to me but I am a newb.
FC -0
CC -0
pH -0
TA -0
CH -didn't test
CYA - 100
FC -0
CC -0
pH -0
TA -0
CH -didn't test
CYA - 100
