Thread: New Pool numbers wayyy off
    Jul 2013
    Louisiana
    2
    Ok i am new here and new to owning a pool which came with the house I purchased. Bought the TF-100 kit and went to testing. First test was chlorine. Added one scoop to 10ml and water didn't even turn pink. So I guess I have no chlorine in the pool. Next tested TA. After adding R-0007 mixing, then add 5 drops of R-0008 the water turned pink instead of green. What does this mean? Finally I tested CYA and it came out around 100. I justed moved in and previous owner used only chlorine tabs and also took water sample to pool store once in a while to have them tell him what was needed. Am I right in assuming i am going to have to do a partial drain and fill to get this back on track? Numbers seem way off to me but I am a newb.
    FC -0
    CC -0
    pH -0
    TA -0
    CH -didn't test
    CYA - 100
    21K IG Vinyl; Hayward S244S Sand Filter; Hayward Super Pump
    22,543
    Re: New Pool numbers wayyy off
    Welcome to TFP.
    You list zero for pH. That can't be right, but since you have almost zero TA it will be too low to test. I would work on getting the TA and pH up before doing anything else. However if you can quickly drain anf refill half of the pool water that would be acceptable as it would ten take less soda ash to adjust the pH & TA. The issue is that you don't want to leave the pH that low any longer than absolutely necessary, and you don't know how long it's been that way.
    Jun 2012
    Howell, NJ
    977
    You should do the CYA test again, this time with half pool water and half tap water and double the result to get a better idea of where your CYA really is. The test tends to report anything over 100 as 100, so it could actually be higher.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
