Results 1 to 19 of 19
Thread: Pool Heater Cost Question
    Jun 2010
    Toronto, ON. Canada
    230
    How much does it cost to run a pool heater? Any calculators out there?
    Want to know what it costs for me to heat up the pool say by 10 degrees...
    We have a 266,000 BTU heater.
    Cost for NG in Toronto is:
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24 Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    Re: Pool Heater Cost Question
    I have no idea how our rates compare to yours - it costs me $100 per month to heat my pool in the winter. My guess is I am not heating it quite 10 degrees (we live in Houston) - maybe 7-8. I have a 30,000 gal pool. Hope that helps.
    Snazzy,
    30,000 Gallons IG, DE filter, SWG, Plaster, 2 HP centurion for filter and same for waterfall, 20+ years old, Polaris 360, hot tub attached
    mas985's Avatar
    Pleasanton, CA
    11,737
    Are you talking about a single time heating it up or maintaining the pool at 10 degrees higher than normal? The first is easy and there are several calculators to do that including one in my signature (Pump and Pool Spreadsheets). The second is a bit more difficult because it depends on how much heat is lost overnight and if you plan on using a pool cover. I have some approximations for this in the spreadsheets but they are only approximations.
    But for a single 10 degree rise, 80% efficiency, that would be about 1.44 M BTU and cost close to $8.
    Mark
    Jun 2010
    Toronto, ON. Canada
    230
    Thanks for the help.
    The weather in Toronto is not favorable at all
    Highs of 65-70 and overnight lows of 55
    Every time we want to use the pool it's at 74 and we need to get it to about 84 to feel comfortable...
    Would covering it (with what?) help?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Solar covers (bubble) can have up to a 15 degree gain so you might not need a heater at all but it depends on your weather. This is the type of cover I am talking about:
    http://www.intheswim.com/landing/solar_ ... ummer.aspx
    Mark
    Aug 2009
    SW Wisconsin
    518
    Totally agree with mas985. If you want to retain the heat from your heater, you MUST HAVE a solar blanket. Get at least a 12 Mil, and it'll help heat your pool, and retain that heat on those cooler nights.
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jun 2010
    Toronto, ON. Canada
    230
    Thanks!! 15 degree gain!? That would be awesome.
    When do you put the cover on? All the time when not using the pool or just at night?
    Also, how are they held in place? Our pool is irregular in shape.
    Jun 2011
    Long Beach, CA
    2,778
    You buy an oversized cover and cut it out to the shape of your pool. It is best to unroll it and let it stay out in the sun for a couple of days before you cut it as it will expand some. Cut it out with bubble side down and it easily will cut with scissors.
    You want the cover on at night as this will keep the water from evaporating. Evaporation is what lowers the pool water temperature. If it is windy, having the cover on will help also.
    mas985's Avatar
    Pleasanton, CA
    11,737
    I have a free form shape and here is what I did for the cover and roller. Note the roller is attached to the cover.
    DIY Solar Roller
    With the cover I usually don't need any solar run time and currently, our average 24 hr air temperature is 73 degrees and the pool reaches 86-88 by the end of the day.
    Mark
    Jun 2010
    Toronto, ON. Canada
    230
    Thanks. Is there a recommended brand for a cover?
    Jun 2011
    Long Beach, CA
    2,778
    You can search this site, http://www.solarcovers.com/ and get some ideas. Most people report that the covers last about 2-3 seasons before the cover breaks down regardless of thickness.
    Jun 2010
    Toronto, ON. Canada
    230
    Our PB just gave us a cover today.
    Its 18x36 (our pool is 16x34). We have teh cover and a roller.
    He said that it just sits on the coping and is bigger for overlap...
    I though that it was supposed to be cut to fit and float on the water?
    Am I confused?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Normally it is cut to fit because if goes over the coping, the wind can blow it around easier. Plus it looks nicer. Your PB is probably just being lazy.
    Mark
    Jun 2010
    Toronto, ON. Canada
    230
    Looks like I'll have to do it my self.. We have the poles and roller as well.
    Are there any tutorials on where best to place the roller based on my pool pic above and how I should set it up? Should the blanket be hooked to the roller in the middle or at the end?
    Need help please...
    Jun 2010
    Toronto, ON. Canada
    230
    Quote Originally Posted by mas985 View Post
    Is there an updated link for the calculator? Thanks!
    mas985's Avatar
    Pleasanton, CA
    11,737
    Use the link in my signature instead.
    Mark
    daleyfolk's Avatar
    Jul 2014
    Boise,Idaho
    51
    In April I had a 266k gas heater installed for my 17,500 gallon pool. Water was at 60. Raised it to 84 the first day and I keep the solar cover on most of the day and all night. I run the pump/heater about six hours a day. My first bill for 28 days was $176. At 90 cents per therm. Weather temps in Boise were similar to what you describe.
    17.5 K gallons (16x32) vinyl inground pool with 1 hp pump and an old Triton sand filter. >20 years old. New 2015 Rheem gas heater. TF-100 Test kit. Little red robot and a Pool Blaster Max.
    Jun 2010
    Toronto, ON. Canada
    230
    Thanks!
    Jul 2013
    Long Island, NY
    141
    I have a 335k natural gas pool heater and it costs $3/hr to run in NY, raising my 33k gal pool by about 1 degree per hour.
    20x40 in-ground Bella Blue Pebble Fina pool w/diving board, 1 HP Hayward Superpump, Raypak RP2100 335k BTU NG mV heater, Pentair Quad DE 60 filter, Pentair 261173 multi-port valve, Stenner 45MPHP10 pump w/15 gal tank, Intermatic ET1125CR dual electronic timer, 1.5" lines, two skimmers w/socks, Poolskim, vacuum line, ColorQ Pro 7 kit, TF-100 kit, speedstir, 2 froglogs, Dolphin Discovery Robot. Wine is the answer, what was the question?
