Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Which filter should I go with, Sand, Cartridge, or D.E.??
    Jun 2013
    Southeast Pennsylvania
    125
    I never knew how many choices and how difficult it would be to decide on what to go with for my new pool!! LOL!!
    I am pretty certain I am going with salt if any of that matters for this post. I know need to decide what kind of pool filter to go with....It seems D.E. is the best and that is what my builder is going to put in.....a Jandy 2HP model for a 400 s.f. pool (up from 1 1/2HP because of 2 decents will run off the pump). What do you recommend...sand, cartridge or D.E.??
    Thanks!
    Doug
    13,500 Gallon Gunite Aggregate Finish, DE, SWG, 2.0 HP pump, 1.0 HP pump for 3 Sheer Descents
    38,284
    Re: Which filter should I go with, Sand, Cartridge, or D.E.?
    Personal preference. There is an article in Pool School that discusses the different types of filters. They all have pluses and minuses.
    You should seriously look into a 2 speed pump or you will be wasting a lot of electricity running that big pump even when the shears are off.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Some places have restrictions on dumping DE into the sewer or out onto the ground so you have to have a recovery system. Places with water restrictions sometimes do better with a cartridge because you don't backwash. Cartridge filters can be tall so can be difficult to clean under decks. Sand filters are slower in clearing dirty water. Like Jblizzle says mostly personal preference.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    May 2011
    Montgomery, TX
    176
    I prefer a large cartridge filter. low maintenance. I only clean mine out once a year.
    mas985's Avatar
    Pleasanton, CA
    11,737
    With an SWG I would lean more toward a cartridge because backwashing removes salt and CYA which will then need to be replaced each time you backwash. You don't have a location in your profile so do you close your pool in the winter?
    Mark
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I like my DE filter and have converted to using cellulose fiber media in it. You can't get better and clearer filtration. But it does require a bit more maintenance. I back flush (I do have a separation tank) and refill with fiber media a couple times during the season and do a full breakdown cleaning once.
    Sand filter has the least, maintenance, but also doesn't filter near as fine. That can be overcome somewhat by adding cellulose each time you back flush. It also wastes the most water do to frequent back flushing.
    Cartridge, predictably, has filtration not near as fine as DE, but better than sand. No back flushing,so less wasted water. But that means you have to do a break down to clean it. If you ever get an algae bloom, that can be a real PITA.
    There are advantages and disadvantages to each type.
    chiefwej
    Jun 2013
    125
    mas985,
    I updated my profile....I'm located in Southeastern, Pa. I am not sure I am worried about replacing salt as it is cheap....don't even know what CYA is at this point! How often would I backflush with D.E.?
    Doug
    Jun 2012
    Howell, NJ
    977
    That depends on what size filter you get and the size of your pool. I personally have a cartridge filter and wouldn't replace it with anything. My fill water is full of iron and very acidic, so minimizing water loss is my goal.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    CYA=stabilizer.
    How often you need to back flush depends on a number of factors. How much dirt and debris gets into the pool, how picky you become about water quality, pump run time, etc. but you should expect at least a couple times a season.
    If you spend some time on this site, reading all the info in Pool School you will find that almost all of your questions are answered.
    chiefwej
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by dubele
    Since you live where you would close the pool and probably only keep it open for 3-4 months, you might get away with one cleaning per season if you get one large enough (~48 sq-ft). But for a winterized pool, clean up is easiest with a sand filter, DE next, and cartridge is probably the hardest.
    Mark
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Like others have said each has advantages and disadvantages, but without knowing a lot more about your particular location it is hard to even make a suggestion, for example do you have a good location for running a backwash line , can you dump DE in the sewer system where you live? (this can be restricted for environmental discharge reasons , or it may clog the sewer processing plant filters.)
    May 2013
    Miami, FL
    23
    Quote Originally Posted by brg88tx
    Holy cow that's amazing. I am cleaning mine every two weeks.
    pool owner since 2012
    13-15k gallons, kidney shaped,in-ground plaster
    1970s construction, currently undergoing complete renovation
    3 jets, 1 skimmer, 1 dedicated vacuum line, kreepy krauly great white, main drain
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    D.E is the only way to go !!!
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    We've got a sand filter and LOVE IT! our pool is crystal clear, backwash once a month only because I feel better about it not because pressure has built up. Each spring I use the garden hose to float out any particles that aren't back washed out. We're on year 2 using the same sand. Until we start seeing a problem I have no plans on replacing the sand for the next couple of years.
    Caveat.. I have no idea how a sand filter would do with a SWG system.
    21' AG (~11,000 gallons)
    Hayward S180T sand filter (35 gpm)
    Hayward Power-Flow SP1510 pump
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by fireman00
    Me too.
    With very rare exceptions, the sand should last the life of the filter without ever needing to be replaced. The sand in my filter is going through its 7th season and the water is still crystal clear.
    Quote Originally Posted by BoDarville
    Me too.
    That's what I heard and why I went with sand...thanks!
    Jun 2013
    125
    This may be one of those things where if I had three identical pools in my backyard and one had a sand, one had a cartrdge, and one had D.E. I would bet you couldn't tell the difference??
    I am going to have the filter on the side of my house. I will be backwashing to the street and let it go down the street drain. This will go into a stream....but it is a long way to the stream....so, it is not going down my house drain and to the sewer processing plant. Who do I ask if there is a restriction for dumping this water in the street???.....and does it really matter? Is this stuff toxic? If it is not safe enough to dump water into the environment, do I really want to be swimming in it??
    Doug
    30,419
    I completely agree. Filtration by each type is perfectly adequate as long as you have a large enough filter and you manage your pool water correctly.
    If you swim in your pool, obviously you have nothing to be concerned about toxicity when you clean/backwash.
    That said, local governing authorities may have some restrictions as to what goes in their sewer system.
    Jun 2011
    Long Beach, CA
    2,784
    Doug
    If this is the case, I would not go with DE as it will get everything coated white with DE and I would not put that stuff into a stream. Personally I would chose a large cartridge filter in this situation.
  20. Back To Top    #20
    mas985's Avatar
    Pleasanton, CA
    11,737
    Remember that the OP closes the pool for the winter so a cartridge will be a PITA during opening.
    If you do decide on a cartridge, just make sure they plumb in a filter bypass and a filter to waste function that is normally not part of a cartridge installation (i.e. cartridge filters don't have a multiport valve). That will be the only way to make a cartridge workable during an opening.
    Mark
