Results 1 to 10 of 10
Thread: Household bleach vs store bought chlorine
    Ok so everybody seems to say just use bleach when needing a quick boost to chlorine levels since it is so cheap.
    but according to this link it is 11 times less concentrated
    http://www.ehow.com/facts_6153959_pool- ... leach.html
    Located in Ottawa, Ontario Canada
    23K Gal, AG, Cart filter, 1.5hp 2speed hay PowerFlo Matrix, Install Sum'13, Aquatrol SWG, Solarbear panels, kreepy Krauly E-Z Vac, TF-100
    Artesian ~500gal Grand Gayman Island Spa
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Household bleach vs store bought chlorine
    Yes, and different blands of bleach have different concentrations. Overall, the bleach tends to be cheaper, that's why it's recommended here. You'll use more of it, but pay less (sometimes, the pool chlorine is cheaper. You have to work out the cost per ounce, and go with the cheapest. Either works fine - they should, they're the same thing in different concentrations).
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    22,551
    And your point is??
    Keep in mind that bleach doesn't add any unwanted chems to your water. And there are several cost comparisons here that show that bleach is the least costly of all the added chlorine sources.
    Read the first sentence and that should give you and idea of how much to trust what they say. "The most common source of pool chlorine is calcium hypochlorite" If you look in all the stores and read here some you'll see that trichlor is far more common than cal-hypo.
    Jul 2011
    844
    I am assuming he meant liquid chlorine, not the pucks. In that case, they're the same, as long as he gets regular bleach, unscented, no additives.
    Bestway SWG
    thehowheels's Avatar
    Apr 2013
    SoCal
    120
    Quote Originally Posted by outdoor
    The concentration of chlorine per gram is totally useless, unless you're worried about how much energy you need to put into transporting the stuff.
    What's important to most of us is the actual cost of using the product. Check out chem geek's post, Cost Comparison of Chlorine Sources.
    Matt
    9k gallon, plaster, IG. Raised spa w/ spillover into pool. AO Smith Century Centurion / Purex Triton WisperFlo 0.5 HP, Hayward 1.5 HP (spa), Polaris 1-516-01 1.5 HP (blower). Hayward DE3620 36 ft2 72 GPM DE Filter, Polaris 145 cleaner. Pool built ~1980.
    Trouble-free, BBB since: April 25, 2013
    Jun 2013
    SpringHill FL
    415
    His link is compareing calhypo to liquid bleach
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    30,424
    Exactly!
    Jun 2013
    SpringHill FL
    415
    Like trying to compare a chainsaw to a steamroller
    Nathan
    Donldson's Avatar
    NW Ohio
    2,903
    Quote Originally Posted by thehowheels
    Exactly. If that were important then everyone would use direct chlorine gas injection.
    Bleach is recommended because it adds the least extra:
    -Bleach adds about 1.5 ppm salt per ppm of chlorine.
    -65% cal-hypo adds 1 ppm salt and 0.7 ppm calcium per ppm of chlorine.
    -Dichlor adds 0.9 ppm CYA and 0.8 ppm of salt per ppm chlorine.
    -Trichlor adds 0.6 ppm CYA, 0.8 ppm salt, and a slight decrease in pH per ppm of chlorine.
    Since salt is the most benign of these things it is better to just add salt than calcium or CYA. Lithium hypochlorite also only adds salt but it is far more expensive per ppm than bleach. Bleach is king because it does what we want it to do and not much else.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mar 2007
    San Rafael, CA USA
    12,082
    From the article:
    One gram of pool chlorine (65 percent calcium hypochlorite), dissolved in 1 liter of water, would provide a FAC level of 0.47 grams per liter, whereas the same amount of household bleach (6 percent sodium hypochlorite) dissolved in the same amount of water would provide a FAC level of 0.04 grams per liter.
    Thus, gram for gram, the pool chlorine will provide 11 times more FAC than household bleach.
    Bleach prices vary, but from this post in a thread with perhaps a hundred or more bleach prices from 2013, 96 fluid ounces (about 2939 grams using 1.08 g/ml density) of 6% bleach is $1.29 so that works out to 0.044 cents per gram. Cal-Hypo the cheapest I could find here is $161.84 for 90 pounds (about 40823 grams) so 0.40 cents per gram or 0.40/0.044 = 9 times more expensive per gram than bleach. In terms of the FAC level that they quote, the ratio was 0.47/0.04 = 12 times higher. So for this huge amount of Cal-Hypo compared to the small quantity of bleach, the Cal-Hypo is 3/4ths the price per FC. However, most Cal-Hypo is not at the extremely low price I found. Much more typical is this where you get 25 pounds (11340 grams) for $61.43 so 54 cents per gram so over 12 times more expensive per gram than bleach making Cal-Hypo and bleach more of a wash. Actual prices will vary around the country.
    Of course, with Cal-Hypo, it increases CH while with bleach it does not. Between Cal-Hypo and Trichlor or Dichlor, Cal-Hypo would be better to use because the rise in CH is proportionately slower relative to when it becomes a problem (compared to CYA with Trichlor/Dichlor).
