Results 1 to 14 of 14
Thread: What lights can be installed on a raised wall above water?
    Jul 2013
    Saint Louis, MO
    24
    I'm having no success finding lights that can be installed in a raised wall at the end of my pool. It is a 24" wall extending up from the deep end. There are 2 sheer descent waterfalls, and I thought it would look nice to have a light in the wall behind each waterfall. What I was planning on using is what is called a deck, step or brick light. Recessed, with a face approx 3 x 8 inches. Louvers direct the light down. They would have a fairly low light level, so I don't think glare off of the water would be too bad (and they're behind waterfalls). I wanted the same thing on the opposite end of the pool, where there is an exposed wall on the outside of the pool structure. I found out that low voltage landscape lighting is not allowed within 5 feet of the inside edge of the pool. My pool builder said that his suppliers know of no approved light to use in this setting.
    What lights can be used near the pool edge?
    ____________________________________________
    18x40 ft shotcrete, 4-8 ft deep. Pebble Sheen finish. Coverstar auto cover. Hayward c4030 filter. Hayward H series 300k BTU. Intelliflo pump. Intellichlor IC40. Pentair Easytouch controls. Dolphin Nautilus robot.
    Apr 2013
    Sacramento, CA
    2,769
    Re: What lights can be installed on a raised wall above wate
    Fiber Optic. Do some searches and you may be able to find something that does what you want. Apparently the next edition of the Electrical Code may permit certain low voltage lights within five feet. But that is at least 2 years away.
    Apr 2013
    DFW, TX
    72
    You can check out these (or other) low voltage lights:
    http://www.landscapelightingworld.com/W ... s-s/40.htm
    Quote Originally Posted by jamgolf
    Nice try but no, not at the water's edge. Need fiber optics as previously mentioned.
    Apr 2013
    DFW, TX
    72
    Quote Originally Posted by AZHeat
    One of those lights is actually for under water usage in ponds and waterfalls.
    The original poster can decide for himself.
    Apr 2013
    Sacramento, CA
    2,769
    Sure he can decide for himself, but instaling those loghts violates the NEC. Let me try and explain the problems. First, the NEC currently prohibits, with some very small exceptions, permanent electrical fixtures within five feet of a swimming pool. A swimming pool is not a pond nor a waterfall. Fixtures designed for ponds or waterfalls do not comply with the requirements of the NEC regarding pools. The big exception is pool lights. If your light complies with a pool light then it is allowed.
    The NEC is trying to prohibit any source of stray current shocking a person in or around the pool when they are most vulnerable
    There are a range of fiber optic products out there. Sure they have limitations but can often do what you want.
    May 2013
    Tulsa, OK
    83
    What about an actual pool light with a custom cover made for it to project the light down. Then you comply with all safety regs?
    12x24 Doughboy. 8700 gallons~ 2 HP Dyanmo Pump~ 26" Sand Dollar Filter~TF 100 test kit~ Zodiac Ranger AGP automatic cleaner.
    Apr 2013
    Sacramento, CA
    2,769
    Sure under certain circumstances that might work. However, if you want to comply with the NEC then the completed housing, the light, and the run back to the sub panel (not just the deck box if you have one) all must comply with NEC 680. A fiber optic light with its source more than six feet from the pool does not need to comply with any of those requirements (the source light fixture may still need to be bonded).
    The NEC is trying to remove any source of stray current from entering the pool area and shocking bathers. The NEC then goes one step beyond and requires all conducting elements associated with a pool be bonded so that even if its first two lines of defense fail (insulation and GFCI) then you still won't get shocked.
    Sep 2012
    Lake Nona, Florida
    386
    I'm in a similar quandary... we put in a small rock waterfall and wanted to backlight it, basically make the water glow a bit at night. It was one of those "design on-the-fly" things and we went round and round with our subcontractors on what we could use and meet code. We bumped up against what gwegan mentions that the NEC specs protections from the failures that protect you from failures of things that protect you. That is compounded with the issue that a lot of lights spec'd for pool use are also only spec'd for use below water. I found the fiber stuff too pricey.
    At this point we ended up re-routing the conduit we ran for the waterfall to a spot just behind the waterfall but outside the screen enclosure. It is tentatively wired off a 110V automated relay from a ground fault protected circuit. What we do from there is still a mystery to me.
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
    Apr 2013
    Sacramento, CA
    2,769
    Davelinde:
    I feel your pain. While it is expensive fiber is probably the way to go. Its on my list for my waterfall in about a year, or I may wait for the 2015 code changes which may, repeat may allow some low voltage lights in these situations.
    Dec 2009
    Central Massachusetts
    2,690
    I did 12 volt lights ( CAST brand) around my inground. A couple of the path lights are less than 5 feet. I'm not he least bit worried. Neither was the inspector when he was out and saw them while inspecting something else. That part of the NEC that prohibits them needs to be changed. Sounds like its going to be; it should, it's a stupid rule.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Most inspectors aren't that generous. Still, it is worth asking your inspector about it. You might have someone accommodating, as bk406 did.
    Jul 2013
    Saint Louis, MO
    24
    Our inspectors are not known for being generous or forgiving... I will probably just abandon the idea of lighting these features. The fiber optic waterfall lights don't give the natural effect I am thinking of, so I did not want to go with those. There will be nice landscape lighting around the pool deck. We should be ok.
    Dec 2009
    2,690
    Cant you just wire it up, cover it up, and install it later?
