Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Time to SLAM
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Time to SLAM
    UPS just arrived with my TF 100. Here are the initial test results:
    FC - 9
    CC - 3
    PH - 7.2
    CYA - 50
    Looks like raising the FC to 20. Not as bad as I thought it would be. I currently have 2 121oz bottles of 8.25 Bleach. Any ideas how many bottles I should pick up to keep the process going?
    6423 AG Intex 18 x 48 Intex 2100 GPH Sand Filter Pool Pump TF100 test kit
    22,551
    Re: Time to SLAM
    Is there a back story to this? Why do you need to raise the FC to 20 ppm?
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    Algae is present and the pool water is cloudy. Prior to finding this site, I was using the store bought chemicals. Cost me a small fortune and did not do anything to improve the situation.
    22,551
    Re: Time to SLAM
    You're right! Time to SLAM!
    I'd probably start out with about 10 jugs.
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    Thanks Bama, local Publix has them on sale for 2 for $4.
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    1st half hour reading:
    FC - 19
    CC - 0
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    1 hour reading
    FC - 22
    cc - 0
    I am guessing that I have established the shock level. Water appears clearer after 90 minutes but still cloudy. I guess I will check the FC later this afternoon, unless anyone thinks it should be done sooner.
    Jun 2012
    Howell, NJ
    977
    Re: Time to SLAM
    Do it as often as every hour if possible.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    1PM Test
    FC - 21
    CC - 0
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    2PM, 3PM and 4PM test results
    FC - 20
    CC - 0
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    5PM test results. Still holding FC - 20 CC - 0. I brushed the bottom of the pool. Stirred up the gunk and now it is cloudy. But then I expected that!
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    Ok I have a couple of questions. First when is it safe to enter the pool. Second after the slamming has done its job, how long does it take to get the FC back to 6? Thanks in advance
    Jun 2012
    Howell, NJ
    977
    Re: Time to SLAM
    It is safe to enter the pool when your FC is below Shock level, and above your minimum. The chlorine should come down fairly quickly.
    John
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    Latest test results:
    FC - 15
    CC - 0
    Added 49oz bleach to get the level back up to 20
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    2nd day. 1st set of test results.
    FC - 20
    CC - 0
    Seems the level held overnight.
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    FC - 19.5
    CC - 0
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    11AM test results:
    FC - 20
    CC - 0
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    Here is a picture of how the pool water looks now. An improvement since yesterday at the start of the SLAM it was green.
    Jun 2012
    Howell, NJ
    977
    Re: Time to SLAM
    What type of filter do you have? If you have the Intex cartridge, I hear that Unicel and Filbur (at least I think it is Filbur) make cartridges that filter much better than the Intex, and are also reusable. If you have the Intex sand filter, you may want to try adding some DE to it.
    John
  20. Back To Top    #20
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Re: Time to SLAM
    I have the Intex A Cartridge type. I removed the filter this morning, cleaned it out and replaced it. I have heard good things about the Unicel filters. I am planning on upgrading to them once my stock of Intex filters is gone.
