Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: NEW STEREO RECEIVER GETTING TOO HOT AND SHUT DOWN, NEED HELP
    Guys,,
    Please correct my problem..
    Equipment-
    2 outdoor speakers under porch (8 ohm)
    2 rock speakers at pool Outdoor speaker Depot (8 ohm)
    2 independent volume controllers from Outdoor Speaker Depot
    Both have long runs- 100' feet. Used 14 gauge buried in conduit
    Pioneer VSX-523-K Receiver (FRONT STEREO 80W + 80W) power output 140W per channel (5 channel)
    I currently have the pool speakers wired to the front posts and the porch speakers wired to the surround posts. The volume controllers are between the speakers and receiver. Each speaker is wired to the respectable positive and neg terminal corresponding to the side they are on.
    Problem is the amp gets hot too the point of shutting down... in under 5 mins.. I tried using a speaker selector wired from the "front" posts and connecting the speakers off that but that didn't help...
    Let me know any hints or ideas...
    13K IG Pool with Raised Spa
    Jandy E Pump- 2HP Variable Speed
    Jandy CV460 Cartridge Filter
    Jandy LXI 40,000 Heater
    Polaris 9300 Robot
    22,542
    Re: NEW STEREO RECEIVER GETTING TOO HOT AND SHUT DOWN, NEED
    What is the impedence at the receiver on each channel?
    What is the impedence of the volume controls?
    Has it ever worked or is it a new installation?
    Receiver says continues avg output of 80 Watts per channel , min at 8 ohms
    Volume Controls are 100 watts peak, 8 ohms stereo
    I have tried using the set up on a zone 2 setting on my home receiver (7.1) and it also got hot but I thought it was because It was on zone two setting...
    I guess that wasn't the case.. Any help would be appreciated..
    Polaris 9300 Robot
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I would start looking here, and if you can't find anything post about the issue.
    http://www.avsforum.com/f/
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    22,542
    Are the pairs of 8 ohm speakers wired series or parallel?
    Parallel
    Polaris 9300 Robot
    22,542
    So the receiver is seeing 4 ohms at the output.
    Is that a question or comment. I'm not sure? Any suggestions?
    Polaris 9300 Robot
    Apr 2013
    Central Massachusetts
    174
    Putting the speakers in parallel and dropping the impedance to 4 0hms in increasing the loading on the receiver. Therefore more heat.
    I think we need to know more about where the receiver is located? Is it inside, outside, in an enclosed space or a well ventilated space? If its in a box outdoors with no airflow, I think you're going to have problems even if you use the proper load of 8 ohms.
    Try putting the speakers in series. They won't get as loud but the heating of the receiver should be less.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    22,542
    If the receiver is rated for 8 ohms and it's actually loaded at 4 ohms there's no wonder it's getting hot. It's not designed to self limit when it see's a lower impedence than it's designed for. It actually puts out more power than it's designed for.
    Jun 2013
    Fallsburg, NY
    258
    Make sure your impedance matching switch on the volume controls is set correctly. Which volume control did you get?
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    Receiver is inside in a well ventilated closet. I even put a small fan and that helped a bit but still got hot.
    Polaris 9300 Robot
    Jun 2013
    Fallsburg, NY
    258
    Did you check the impedance matching switch on the volume controls?
    Switch is in the correct setting
    Polaris 9300 Robot
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    The impedance is going to drop even further with long speaker runs. How long are they? There are charts available that show the impedence drop per foot of cable at various gauges. You really need an amplifier than can handle very low impedence loads without going into protection such as Harman Kardon or Sherwood. Good luck.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Apr 2013
    174
    Impedance increases with longer speaker wire runs. Voltage drops. So long wires aren't the source of overheating, but they will require you to up the gain/volume to get the same sound output compared to short speaker wires.
    My Build thread
    Feb 2012
    Manvel, TX
    43
    Based on the description of how you are hooked up, it doesn't sound like an impedance issue. You should have separate amps for the front and surround connections.
    I would check the wiring at all your connections to make sure you don't have contact between your positive and negative wires that could be trying to create a short. I would think your length of wire is creating enough impedance that you don't get an instant short but would drop the effective impedance on the amp to cause your overheating.
    Ed Klein
    My Backyard Setup with Pictures
    Pictures of my Build Process
    27,000 gallons total
    IG plaster pool with waterfall/slide and 10' OD hot tub
    SWCG - Pentair IC-40 with Easytouch 8 automation
    Pentair Intelliflo VS+SVRS filter pump with 150gpm cartridge filter
    Built Summer 2012 - Houston, Texas area
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Quote Originally Posted by CAVJOCK22
    ... I currently have the pool speakers wired to the front posts and the porch speakers wired to the surround posts. The volume controllers are between the speakers and receiver....
    The way I read this is that each speaker has a dedicated amplifier output. The fact that it over heated with your 7.1 home receiver makes me think the amp is not the issue.
    I'd start looking for a miswire or a bad volume control. I'd disconnect all the speakers at the volume controls and see if the amp still overheats. If not, I'd hook up each speaker one at a time, making sure that only the speaker that I thought I was hooking up was the one that was on. If the amp does over heat with only the volume controls hooked up, I'd carefully check the wiring to them and if good, unhook one volume control, then the other and see if the overheating continues. If it did, I'd eliminate the volume controls, hooking the amp directly to the speaker and see what happens.
    Happy hunting,
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Mike_W's Avatar
    Aug 2011
    142
    or in other words, +1 on what ultimate_ed said.
    Mike
  20. Back To Top    #20
    Thanks, I will try jumping the volume control this weekend and report in
    Polaris 9300 Robot
