Thread: Hayward salt generator reading 9900 salt level.
    My Hayward salt generator is reading 9900 for the salt reading. The only light that is on is the power light and I am not producing chlorine. Any suggestions?
    9.400Gal, SWG, Sand Filter, IG, Fiber Glass, 1HP Pump 1 Velocity
    22,551
    Re: Hayward salt generator reading 9900 salt level.
    Did it just start this?
    Has it been working correctly in the past?
    Have you had the salt independently tested?
    How old is the unit and the cell?
    What model swg is it?
    When it first turns on the instant salt will read 9900 and then scroll down to the actual leve in about 10 seconds. Is that what's happening, or is it staying at 9900?
    Try turning the switch to off for a few seconds and then back to auto. You should hear the unit turn on. Then scroll through the diagnostics and write down the readings.
    Support the site
    Got home this afternoon and tried recommendations with no luck. Decided to pull cover off and kept messing with switch and button. Heard it click on and other lights came on and salt level is now reading correctly!!! Must have been something in the box not making a good connection. So relieved! My salt cell has outlasted all the others that I have seen posted so I thought it had bit the dust. I'm between 6 and 7th year! Yeah me!!!
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Thats awesome
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    The Inrush Current Limiter on the circuit board might be going bad. Take a look at it to see if it looks cracked or burned.
    http://www.digikey.com/product-detail/e ... ND/2614388
    http://idoneitmyself.wordpress.com/2009 ... lightning/
    http://www.youtube.com/watch?v=TOJ6WcW9CYs
    Support the site
