Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Test, Test, Test
    rmozer's Avatar
    Oct 2012
    Remsenburg/Speonk, NY
    26
    Test, Test, Test
    How can I tell the difference between green and mustard algae?
    I have been battling a murky, green pool for the last week.
    I know the pH is a little low, and I will adjust this morning.
    Here's my latest chemistry as of 8:00 this am:
    pH = 7.8
    FC = 27 ppm
    CC = .5 ppm
    TC = 27.5 ppm
    CYA = 60
    Alk = 130 ppm
    Pool characteristics:
    20,000 gal
    sand filter
    IG, vinyl
    20 gpm/ft2; 2.2 ft2 of filtration area
    Bob Mozer
    Remsenburg (LI), NY
    22,000 gallons
    new Hayward sand filter
    IG
    vinyl
    2 hp Variable speed pump; 20 gpm/ft2 filtration rate; 62 gpm design flow rate
    22,553
    Re: Test, Test, Test
    pH looks a little high to me, not low.
    Have you been follwoing the SLAM instructions correctly?
    How often do you test and adjust the FC?
    How long have you been actually SLAMing the pool? It can easily take more than a week to pass the OCLT.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Can you post a pic? That would help us determine which type of algae you have. Generally, mustard algae is a yellowish color and common algae is green.
    Suggest adding information about your pool and related equipment in your signature. By doing this, it will automatically appear in all your posts so you do not have to re-enter it each time. If you have a SWG, please include those letters in your signature so it stands out as the advice for SWG vs. non-SWG is often different. Here's how to do it: Adding location to your profile and pool info to your signature.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also remember the pH test tends to read high at FC levels over 10 ppm, our general advice is not to try to adjust pH while at shock levels.
    rmozer's Avatar
    Oct 2012
    26
    I just edited my profile as you suggested.
    I am also adding a link to a picture of my pool as of just now.
    I hope you can help me. I ran into this problem last summer as well, and I was off to a good start this year. We've had a run of hot, humid weather here on LI. I was just starting to see some improvement last week, but then I went away for the weekend and I came home to this mess.
    Thanks.
    Bob
    https://docs.google.com/file/d/0B2Sb1zi ... sp=sharing
    22,000 gallons
    IG
    vinyl
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    rmozer:
    I tried to look at your pics, but am sent to a login screen for Google Docs. Can you post your pic either directly to this thread or to another site that does not require a login?
    rmozer's Avatar
    Oct 2012
    26
    sorry, I need to change the settings so you don't need to login.
    try it again in a few minutes.
    Bob
    22,000 gallons
    IG
    vinyl
    rmozer's Avatar
    Oct 2012
    26
    I just reset the permissions, and here's a new link, just in case it's different than the first one I sent.
    Bob
    22,000 gallons
    IG
    vinyl
    Looks like common green algae. Follow SLAM, and you should see the color become a little duller/grayer each day, then the green will gradually turn to blue. The trick is to stay on top of it, and keep the FC as close to your target of 24 as you can throughout the day. If the FC drops, the algae grows again, so you'll need to make sure you have time to dedicate to keep it up. Over time, the FC won't drop quite as fast any more, but this could take a few days.
    SLAM: http://www.troublefreepool.com/pool-...king_your_pool
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    rmozer's Avatar
    Oct 2012
    26
    OK. I understand what to do.
    Unfortunately, I just ran out of the indicator chemical to test for FC. I ordered more, but now I have no way of testing until it arrives next week. Is this a chemical I can purchase locally at a pool store?
    As for the chemistry of my pool, when I checked it yesterday, the FC was >45 ppm as I had added about 1 gallon the night before to try to stay ahead of the algae. If I can't find the indicator chem for FC, should I add some liquid bleach each day just to stay ahead of the algae until I see some changes?
    Thanks.
    Bob
    22,000 gallons
    IG
    vinyl
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Do you have one of the recommended test kits ? It's the right tool for this job. Best investment you will make for your pool.
    Jeff
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What test kit are you using now ? Can you post the rests from your last test.
    Jeff
    rmozer's Avatar
    Oct 2012
    26
    I have the test kit from TFP, but as I said, I ran out of the FC indicator chemical (R-0871 FAS/DPD). I just ordered more from TFP, but I won't get it until next week. If I could get more of it locally, I'd be back in business.
    Thanks.
    Bob
    22,000 gallons
    IG
    vinyl
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    No you can't get it locally. Can you post all of your last test results ? You can hold it at bay by adding bleach till your reagent gets there.
    Jeff
    rmozer's Avatar
    Oct 2012
    26
    I will test everything I can this morning.
    BTW...can I get MSDS for each of the test kit chemicals? I am a science teacher, and I like to know more about the chemicals I'm working with.
    Thanks.
    Bob
    22,000 gallons
    IG
    vinyl
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Check out Taylor's website. I believe they do have the MSDS available for everything in their kits.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would think so. That would be a good question for Duraleigh Maybe shoot him a pm.
    Jeff
    rmozer's Avatar
    Oct 2012
    26
    Thanks Jeff.
    Is the R-0871 titrating reagent really not something I can get at a local pool store?
    I already ordered some from TFPs, but until it arrives, I'm driving blind.
    Bob
    22,000 gallons
    IG
    vinyl
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    rmozer:
    Thanks for resetting the permissions...I was able to see the pic. Looks like green algae to me.
    Keep adding bleach to maintain SLAM levels. Based on your recent additions and chlorine consumption, you should have some idea of the amount of bleach it will take to maintain this level. It's about the best you can do until your reagent refills arrive.
  20. Back To Top    #20
    rmozer's Avatar
    Oct 2012
    26
    Thanks for your help.
    I will post my chem results later today.
    If adding 1 gallon liquid bleach gets me to about 45 ppm FC, will this cause damage to my vinyl pool liner?
    I don't want to lose my battle with the algae, but also don't want to cause damage to the pool.
    Bob
    22,000 gallons
    IG
    vinyl
