Thread: equipotential bonding
    Jul 2013
    Downers Grove, IL
    11
    According to county code I need to bond 4 uprights, the wall, pump and conduit......
    I bonded the uprights, pump and conduit, BUT..........
    The pool is filled, is there an easy way to bond the wall?
    I know you can bond it to the bolts that connect at the wall seam, but that is covered by the upright.
    15 x 30' - 52" above ground
    15 x 30' - 52" oval Mighty Sun
    1.5hp pump - cartridge filter with frogger.
    22,553
    Re: equipotential bonding
    You may be able to pull a top rail or two off and get to the top seam bolt. You could attach a lug there and route the wire down the upright and connect it to the loop. That should satisfy the inspector.
    Jul 2013
    Downers Grove, IL
    11
    I'll take a look at it tonight, thanks
