Thread: SWG ok with copper plumbing?
    I just consulted with the contractor who put in the fiberglass lining years ago and at that time advised strongly against a salt system because of potential concrete damage. That is why I went with the copper ionization system I am unhappy with. I wanted his advice on how to get the copper out if I did decide to go with a SWG. He agrees with my plan to get it out with oxalic acid which I used regularly before the ionization system to keep metallic ions out of the water. He also indicated that salt is highly corrosive to copper pipes. Unfortunately all my underground pool plumbing is copper (above ground PVC). The pool was built in 1969 before PVC was allowed underground for pools here. Is this a big issue to be concerned about? If so, enough to scrap plans for a SWG?
    21,000 gallon igp, fiberglass lining, Hayward S244T sand filter with Vari-Flo valve and glass media, Pentair IntelliFlo VF, Barracuda G3, Argenia Copper Ion system
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: SWG ok with copper plumbing?
    I don't see how oxalic acid removes copper. Oxalic acid, just like ascorbic acid and citric acid, is a reducing agent as well as being a weak acid and can help to remove metal stains, but that is not the same as removing copper ions in the water. Do you have any references that describe how this works?
    This thread was not intended to be a discussion about oxalic acid, rather whether installing a SWG system in copper plumbing is a serious problem or not. After consulting again with my pool contractor he indicates that the health department will not let any commercial pools with copper plumbing install SWGs here in southern California. He also claims that many of the potential problems may be overcome by using a sacrificial zinc anode connected to the plumbing bond. There are several different manufacturers of these online, the most popular seeming to be units made by PoolToolCo. Anybody know anything about these systems and whether they really work or not? There seem to mixed opinions on other online pool forums regarding these anodes.
    Regarding the oxalic acid. It is a well known and used sequestering agent for pools and commercially sold under the name of Pool Stain Treat. I am not a chemist, so cannot even begin to explain how it works. Inquiries in this regard should be directed to United Chemical Company who makes it. From the getgo my fiberglass contractor stongly suggested treating the pool every 60 days with 2 pounds of oxalic acid to keep out the various metal salts which tend to accumulate in a pool. We did this fairly faithfully with good results until installing the copper ionization system. Only bought the Pool Stain Treat once at a pool supply store for around $20 per 2 pounds. At that point I started buying oxalic acid in bulk quite reasonably until the government decided to label it a hazardous material. Now I cannot find it anywhere at a reasonable price in bulk quantities though I notice it is currently available on Amazon in 10 pound bags for about the same price as a 2 pound container of Pool Stain Treat.
    Mar 2007
    San Rafael, CA USA
    12,082
    SWGs are used in many pools with copper heat exchangers in the gas heaters. There is an increased risk of corrosion, but it is not absolute -- that is, it is not seen in all systems or even in most systems. You are correct that one can use a zinc sacrificial anode connected to the bonding wire and that will help protect all metal connected to that wire. The zinc sacrificial anode should be buried in moist soil to be most effective. This approach is also used to protect aluminum headers in vanishing automatic covers since that is where most metal corrosion occurs in SWG pools.
    As for oxalic acid, I was referring to your plan "to get it out with oxalic acid", referring to copper. I thought you meant removal of the copper ions in the pool, but oxalic acid is used, just as ascorbic acid or citric acid is used, as a reducing agent to remove existing metal stains in the pool, but this does NOT remove copper ions from the water itself. One then needs to use a metal sequestrant to hold the copper ions so that re-staining does not occur (oxalate could be used for this, but not when chlorine is present since chlorine oxidizes it). One cannot use oxalic acid, ascorbic acid or citric acid on an ongoing basis (i.e. kept in the water) with chlorine in the pool since these reducing agents will react with chlorine to consume it. That's why I was confused. So it sounds like every 60 days you used oxalic acid, which would force the chlorine level to zero and would remove any metal stains, but would then put those metal ions into the pool water. As described in the link to Pool Stain Treat, it is a stain remover and contains oxalic acid as listed in the MSDS, they also claim it contains a metal sequestrant to last for 60 days. They are likely referring to oxalate, the salt of oxalic acid that forms in pool water, but that will not last once you add chlorine to it.
    The reason it is important to set this straight is that we don't want people going out and buying oxalic acid and expecting it to prevent re-staining. It won't. It will remove stains, but a metal sequestrant is then needed because chlorine will oxidize the oxalic acid. The Pool Stain Treat either has both in the same product (if I take their "continues to work for up to 60 days keeping metals water soluble and preventing future stains" claim at face value) or their claim is a lie in chlorinated pools. That's why they say it only holds onto the metal for 60 days and you need to re-treat. If it physically removed the metals (say by precipitation into the filter and then backwashed/cleaned), you wouldn't need to add more product unless more metals were added to the pool with fill water.
    When you started buying oxalic acid in bulk and using it, you were using it as a stain remover, but it did not physically remove metals from the water, at least at low concentrations. At high concentrations of metals, they can be precipitated with oxalate such as calcium oxalate as shown in this post. There are also quite a few posts on this forum (and others) about oxalic acid use and re-staining has been seen if the level of metals is high and not enough separately added metal sequestrant was used.
