Results 1 to 11 of 11
Thread: Adding bleach daily?
    Jun 2010
    NE Ohio
    52
    I'm new and very pleased with BBB.
    My numbers are great and the pool looks good (Knock Wood!)
    My only question is it normal to be adding a bit of bleach daily? It's not much but when the pool calc calls for it I do.
    I think it's hard to break the puck mindset of drop it and forget it for days.
    24' round/52" deep Leisure Bay AG est. 13.5k gallons
    Hayward TS180 Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Adding bleach daily?
    Yes. Read my signature V V V
    Donldson's Avatar
    NW Ohio
    2,881
    Very normal. If you raise it a couple points higher than recommended you can often get by with every-other-day during times where nobody is swimming (which is now for us Ohioans). When people are swimming often or the water temp is over 90 it is best to stay on top of it daily.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How much are you having to add daily and what is your cya level?
    kellyetheredge's Avatar
    Mar 2013
    Lubbock, texas
    43
    Richard 320..that phrase is awesome...so true too.
    14,364gal AGP
    Intex Ultra Frame 16'x32'x52"
    Krystal Clear™ Sand Filter Pump & Saltwater System - 2,650 GPH**Nite-Brite Halogen Pool Light
    TF-100 Test Kit (This kit Rocks)
    Jun 2010
    NE Ohio
    52
    Thanks! I wasn't (too) worried but just wanted to confirm that it wasn't supposed to last for days in there. The first week I was adding bleach in the a.m. (pool gets full sun all day). I finally started adding it at night (failure to follow directions will be noted on my Pool School interim report
    I cheat a little and add 1 gallon every other day...my CYA is 55-60 and I lose about 2ppm per day...the gallon bumps my chlorine up about 4.5 ppm and that usually gets me through 2 days.
    23,000 gallon gunite with waterfall, radiant heat, sta rite system 3 cartridge filter 450 sq. ft., 1 1/2 HP
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by Concho
    This is exactly what BBB allows. Get to know your pool and you can tweak the testing and dosing (to some degree, at least).
    Mar 2007
    San Rafael, CA USA
    12,082
    Note that if you use a pool cover that is more opaque, then the chlorine loss can be less. Mine is around 1 ppm per day as a result and that's with the pool used every day for 1-2 hours so I add chlorine around twice a week. If the pool were kept closed and not used, the daily loss would be around 0.6 to 0.7 ppm per day and the only reason it's that high is that the water temp is around 88ºF.
    Jun 2010
    NE Ohio
    52
    Thanks! We are full sun, no cover so I know that impacts chlorine loss too.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Entirely normal to add chlorine daily during swim season. Organic contaminants are constantly trying to invade a pool and chlorine kills them off before they have a chance to get a foothold. As a result, some chlorine is consumed simply by doing its job as a sanitizer. Sunlight is also another cause of chlorine loss, though a cover can help mitigate loss from this factor.
