Results 1 to 8 of 8
Thread: HI FROM WILLISTON, FLORIDA
    real new to the pool world. I have a 16 inch? sand filter w/1hp pump for my above ground pool. which is great I might add. but I had a small drip coming out of the hose on the filter which I fixed but I loosened the drain plug and now the whole plug and all keeps turning round and round (so no seal). can I replace or what? please help! the dog are ready to go swimming.!!! thanks
    14,667 Gallon 26 x 52 Intex Above Ground Round Cartridge filter ~ filtering capacity of 2,500 per hour.
    Intex Krystal Clear Saltwater System (SWG)
    Purchased and installed in June 2013
    22,553
    Re: HI FROM WILLISTON, FLORIDA
    Welcoem to TFP.
    The drain plug on the pump or filter?
    the drain plug on the filter
    the actual plug is screwd in but the black nut that is attached to the big grey plastic filter keeps turning. I put some pvc glue on it but in SUNNY fla. it has rained for 30 days?
    22,553
    What is the brand and model of the filter?
    It's probably best to just replace the drain plug.
    all I know right now is 3700 GPH 16 sand filter, it is storming outside so I can't go look at it. where do I buy a drain plug? I bought this pump and filter on amazon.com
    22,553
    Once you find out the model, you can look for parts. You can get them online or of it's a common brand the pool store may have them.
    thanks
