Results 1 to 8 of 8
Thread: outside temps/pool temp
    supercanadian's Avatar
    London Ontario Canada
    154
    I did some searching and came up blank on this one. Odd question sorry if it is a repeat. merge if needed!
    What is the ideal temperature ratio relative to outside temperature with wind that is optional to not feel cold swimming or just getting out of the water.
    I know everyone has a preference but I was thinking if the outside temps is say 80 degrees, would it make it seem colder on the swimmer if the pool was 78 or 82? I am thinking about the head/shoulders out of the water. If the pool was 82 and the outside temp plus wind was 80, I am thinking the wind/breeze factor of the outside temps lower than the pool would make it feel "colder" than if the pool was just below the outside temperature.
    I wonder if I heat my pool too much that people seem cold as the outside temps are usually lower than the water.
    Sorry if that makes no sense. Out of work early today and a couple of wobbly pops in the system.
    16x32 Kidney Hayward Aqua Rite Salt Generator, Omnilogic, Tristar Vari Flo Sand Filter, Colour Logic LED, WFSD Waterfall, 250 BTU Millivolt, GVA-24 Valve Actuator TF-100 Test Kit
    Pool 1
    Pool 2
    my build
    38,303
    Re: outside temps/pool temp
    I think humidity is a huge factor. It can be cool getting out of a 90 degree pool with air temps of 100 while all the water is evaporating ... but once the water is gone obviously it gets hot and you want to get back in the pool.
    Jul 2010
    Philly
    332
    Only a Tucsonite can put the words 100 and cool together.
    Another big factor is choice of beverage.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    I find that the amount of sun affects the way it feels more than anything. The water is 81 and at 3 in the afternoon it feels great. At 6, it feels cold. The outside temperature may only be two degrees cooler, but what a difference the sun makes. Same thing on a cloudy day.
    It's called solar load - cars with automatic AC systems have a solar sensor to factor that in.
    Quote Originally Posted by Richard320
    According to Accuweather on Sunday it was 75, I ran the heater and ended up at 88, sounds perfect. When the sun came out it felt warm. 86 probably would have been ideal in the sun, even at 75 outside.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    154
    Thanks for the input folks. I was really curious if it was better to keep the water just below or just above the outside temp so that it does not appear colder than what it is.
    I think I'll try and aim for just at or below the temp plus wind/humidity conditions to keep it the most comfortable. I think if the water is cooler than the air than when above the water or just getting out it won't seem as chilly. Thinking around the 80 temps. I am not talking about 70 lol. 70 is cold.
    Pool 1
    Pool 2
    my build
    Jun 2012
    Louisville, KY
    266
    It depends on sun, wind and humidity for me. Humidity and the dew point play the biggest factor in the temp you "feel". Along with wind on your damp skin, the evaporation is doing the same thing as your sweat = cool you down.
    90 degrees and sunny? 80-84 feels great
    80 degrees and cloudy/windy? 80-82 can be cold with the wind, 84-85 is better.
    70 degrees, no wind, humid and sun down early evening? 82-83 is AWESOME!
    Wife swimming laps? She prefers 79-81 to combat the core temp rise and sweating.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Mar 2013
    Sayville, NY
    53
    We have found that 85 seems to be the ideal temperature for day swimming with little ones. If the sun is out, and it is warm, you even feel good getting out. For night swimming, it seems that 88-90 feels more comfortable as you will get cold out of the water.
    The pool heated up to 92 during our last heat wave and was not refreshing at all during the day, at night it was a dream!
    16 x 32 Vinyl IGP ~22000 G
