Thread: TF-100 Mixed Chlor. Results??
    Jul 2013
    Chicago IL
    83
    I followed directions to a T ::
    When i do a 25ml sample : i get 4.2 FC (21drops to clear x 0.2= 4.2)
    10ml sample : i get 5.0 FC (10drops to clear x 0.5= 5.0)
    Why the inaccuracy???
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: TF-100 Mixed Chlor. Results??
    Well, the test is accurate to +/- 10% always, since we can't be sure every drop is exactly the same size. I'd say those results agree. They're certainly close enough to not be concerned about it.
    May 2013
    Bay City, Michigan
    283
    did you use enough powder in the 25ml sample? I believe it requires more powder than the 10ml sample just due to the extra water. Sure I will be corrected if that statement is wrong.
    Also your chlorine test with the 10ml sample could have been anywhere from barely over 4.5 to 5.0
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Jul 2013
    Chicago IL
    83
    I have both Taylor K-1515 chlor/cc test kit and the TF-100 kit ... Going to do both today when i get home see how they compare...
    38,475
    You are just going to drive yourself nuts trying to compare various. Pick a kit and be consistent and trust the results. What are you hoping to gain with the comparisons?
    Jul 2013
    Chicago IL
    83
    True
