Thread: Non-chlorine "shock"
    May 2012
    South Florida
    36
    pH 7.5
    TA 70
    CH 300
    CYA 50
    salt 3400
    Temp 91
    How long will Non-chlorine shock affect CC test with fas dpd test kit. I sued 2 bags of it because I had it to try and eliminate a .5 cc reading I continuously have despite keeping the chlorine level at 20 for over a week. Why a week? Because I always have a .5 cc reading and our eyes get very irritated. I'm about to give up
    IG ~14,000 Gal
    Pentair clean n clear Cartridge 100g/
    SWG Aquapure 1400
    Hayward XL Cleaner
    Premix Marbletite Freestone series
    1.5Hp 2 speed
    TF-100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Non-chlorine "shock"
    Assuming your were using the 10 ml sample, as long as one drop of the R-0871 clears it up then no need to worry about it. If it takes two, then worry and chlorine and the SLAM process is the solution.
    Mar 2007
    San Rafael, CA USA
    12,082
    Try using a 25 ml water sample where each drop is 0.2 ppm and you may find that your CC is <= 0.2 ppm. If your pool is exposed to sunlight regularly and not covered all the time, your CC is probably low. As for your eye irritation, your numbers look OK so I don't know where that is coming from.
    The non-chlorine shock will usually be gone within a week. It can be shorter than that if there is something in the pool to oxidize. If you were going to use it more frequently, you can get the Taylor K-2042MPS interference remover[/url] to be able to distinguish between the MPS level and true CC.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In my experience MPS typically shows up as elevated CC for about 3 to 5 days after it is added (slowly tapers off), note I do have the Taylor K-2042 test that Chemgeek mentioned since I do occasional use MPS for supplemental oxidation. Of course that is only my experience, and may depend on factors like dose level, etc.
    30,427
    Just a note to point out to the casual reader that Isaac-1 has an indoor pool. MPS has quite a few benefits for an indoor pool but not so much for a properly maintained outdoor pool.
