Results 1 to 12 of 12
Thread: Bury a rigid discharge hose for backwashing?
    May 2013
    Fort Lauderdale, FL
    423
    I currently have a 100'x2" blue discharge hose running across my back yard for backwashing the filter. I want to bury a permanent hose. The yard has a constant slope, so it will drain to avoid freezing. What kind of hose should I use? I was looking for 2" poly tubing, but the internet isn't turning up much. I thought about PVC, but it would be alot easier to unroll 100' of continuous hose and dig a ditch for it (or rent a ditch witch...) rather than glue together 10, 10' sections. I also found 2" suction hose, which is reinforced so it doesn't collapse. Tractor supply has it for $2.19 a foot, so $219 for 100....
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    22,550
    Re: Bury a rigid discharge hose for backwashing?
    I have mine ran in 2" and 4" PVC but 2' Poly would work. Lowes, Home Depot, etc. should have rolls of it. Any plumbing store should have it.
    Dec 2009
    Central Massachusetts
    2,690
    I buried 2" black poly. Big box store or an irrigation supply house will have it.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    May 2013
    Fort Lauderdale, FL
    423
    Great. I didn't see any at home depot. Local hydraulic/rubber supply place can do 2"x100' of PVC spiral suction hose with threaded fitting for the pump for $272. Seems a little high...
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Gluing together 10 sections of PVC is rather trivial, and should not add more than 10-15 minutes to the job, particularly a job like this where you can afford to be a little sloppy (or inexperienced) on your joints since it will not matter if they end up leaking a little.
    Ike
    May 2013
    Fort Lauderdale, FL
    423
    I found this stuff at home depot- 80 psi poly pipe. http://www.homedepot.com/p/Advanced-...0100/203294223 for $169
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    The cheaper type would probably be the black PE (polyethylene) type used for drip irrigation systems.
    This one is somewhat expandable as well, so ice can not damage it, but will make it come off fittings, so after freezing a close inspection of fittings used for this kind of hose is required.
    Don´t be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    I've got about 50 feet of PVC buried.
    Dec 2009
    2,690
    Quote Originally Posted by zimm
    This is what I used.
    May 2013
    Fort Lauderdale, FL
    423
    What did you use for fittings?
    Dec 2009
    2,690
    I didnt need any. I only had to run it 20 feet.
    But to connect it to my multiport I used a plastic 1.5" male/barb fitting and 2 clamps. If you need more than 100 feet, get a barb coupling and 2 clamps on each side of the coupling.
    They should sell fittings where ever you get the poly.
    May 2013
    Fort Lauderdale, FL
    423
    Thanks. I ordered the poly from home depot. They don't have 2" fittings. I'll try the local plumbing supply or the internet. I want to do a 2" barb, then run a couple feet of clear suction hose, then switch to the poly for the 100' run across my yard and down a hill.
