Results 1 to 11 of 11
Thread: SLAM process question
    May 2013
    Chandler Arizona
    78
    SLAM - Shock Level And Maintain
    CC level is above 0.5, and the free chlorine (FC) level is zero, started to SLAM the pool.
    Prerequisites:
    You need to have a FAS-DPD chlorine test
    You also need to know your current CYA level 60 ish, and then look up the corresponding FC shock level.
    USING bleach or liquid chlorine when SLAMing.
    Check and adjust the PH to between 7.2 and 7.5.
    Run the pump 24/7 until you are done SLAMing running on recirculate* should I run filter?
    SLAM:
    Measure the FC level= ** 0.1
    Add enough chlorine to bring FC up to shock level ** up to 25
    Repeat steps 1 and 2 as frequently as practical, but not more than once per hour, and not less than twice a day, until:
    CC is 0.5 or lower;** waiting on fas/dpd reading
    You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less); **I not sure if i was supposed to test this morning with the fas/dpd?
    And the water is clear.** water has always been clear
    Chlorine additions should be frequent, especially at the beginning. Algae and other organic debris will consume chlorine very rapidly at first. As things progress, you will lose less chlorine each cycle and can add more less frequently.
    ***So last night I added enough to get to 25 FC which is my shock level for my current level of CYA. I did not add more yet... How long do I keep it at shock level? Should I have my SWG running? Should my SWG be off during SLAM? My PH was at 7.3 when I started.
    When do I test with the fas/dpd test and how high should FC be?( always at shock level?)
    Brush the entire pool once a day** will do
    Backwash or clean the filter as needed** will do
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    Jul 2012
    Herndon, VA
    419
    Re: SLAM process question
    What exactly is the question?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Jan 2013
    Houston, TX
    1,079
    You should run on filter to filter out any dead algae
    Yes ... If the water is clear bring it up to SLAM - test after sun goes down and again before it comes up.
    Until the water is clear / the algae is dead / you pass the OCLT
    Not for the OCLT ... and optional during the SLAM.
    Optional except for the OCLT - off for the OCLT.
    Always bring it back to shock level.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Recirculate bypasses the filter.
    May 2013
    Chandler Arizona
    78
    So thanks guys for all the great info you've armed me with. Now family is mad at me for starting the SLAM process when the pool was perfectly clear. I was worried because my FC dropped to 0 then would only rise to 1.0. Is it safe to swim in SLAM water 25:FC?
    -Once my SLAM process is complete. And the OCLT is completed. Do I run my SWG and see if FC stays steady between 3-5? and let the liquid chlorine slowly dissapate?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Quote Originally Posted by Ame
    Yes, it's safe to swim up to shock level. If the water is clear, you'll probably pass the overnight test tomorrow morning and then just let FC drop by itself.
    May 2013
    Chandler Arizona
    78
    So my SLAM process seems to have gone well.
    I am now maintaining FC between 7-8 and will be reducing my SWG run time, going to keep it approx FC=5.
    My CC has bee at .5 consistently.
    But 1st I believe I need to raise my CYA a bit from 55 to 70.( I kept it lower during my SLAM on purpose, I knew it was low, And on your advise did not increase until SLAM was done.)
    My PH is a little high at 7.8 but I think that adding CYA lowers PH right? should I get my CYA up 1st before changing my SWG run time?
    Richard320's Avatar
    Jan 2010
    19,074
    You have things figured out.
    If you plug your numbers into http://www.poolcalculator.com/ then scroll down to Effects of Adding Chemicals and plug in the quantity of CYA it calls for, you'll see what effect it should have on pH. Hint: it should lower it almost .3
    May 2013
    Chandler Arizona
    78
    Cool thanks for the CYA hint!!
    Apr 2013
    East Texas
    20
    I am wondering why the CYA needs to go up? Just curious.
    Doughboy 1.5 Powerline & AquaView sand filter and BBB. 12k gallons in 24' vinyl AG.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    She has a SWG. Recommended CYA level for a SWG is 70-80.
    Jeff
