Thread: Hi from Oklahoma
    Hi from Oklahoma
    Hoping someone can point me in the right direction. My wife and I bought a house with indoor pool and it has the old pea gravel around it, its an inground concrete pool. I'm wanting to refinish the surface and was thinking about grouting it. We grouted a small section behind the bar a couple of months ago and no problems so far. Just wondering if anyone had any advice on this matter.
    Thanks in advance,
    Taylor
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Hi from Oklahoma
    Welcome to tfp, foss2
    Just wanted to say hello...I do not have an answer for your question, but hopefully someone will come along who does
    30,431
    Welcome to the forum.
    Grout will not work. Tell us a little more as to what's wrong with the pool surface.
    Thanks.
    It is the pea gravel around the pool and its coming loose which ends up in the pool sometimes. Its also tuff on bare feet when walking around the pool. The area behind the bar that we used grout on is way smoother to walk on and it looks better too. With the pool being indoor I thought the grout would hold up to normal wear and tear.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
