Results 1 to 8 of 8
Thread: Redoing pool- need opinions
    timelessr1's Avatar
    Jul 2013
    North New jersey
    6
    So its finally time to update and redo my 27 year old pool...
    the pool is a vinyl 21X41 Grecian /36k gal. It currently has a 27 year old 1 hp single speed pump that whines like a banshy at times
    The current filter is a Hayward 36ft2 E filter that has a tear on one of the fins which is now leaking DE back into the pool.
    We jsut recently replaced the 27 year old liner, with a new 28 mil loop loc
    Now its time to take out the old and start with the new. i've ben contimplating between DE's sand or Cartridge filters. I'm starting to lean more towards the cartridge filters now..like the Jandy 580...but im still open for suggestions.
    I'm also looking at a Pentair VS with a EasyTouch system 9 or is it less hassle getting a pentai VF with controller built on?
    I'm also debating on getting a SWG or sticking with the old chlorine method... i've read a few posts of ppl having issues with their SWG reading lower then actual salt content inthe pool , and that temp play a big part in these readings...and since my pools not heated...the temp can fluctuate....so im not sure which direction to go.
    and speaking of heating...i dont know its worth getting a heater since we donthave gas here and would have to get a propane unit..which would need the install of a very large propane tank..and thoughs?
    36,000 gallons
    21 X 40 Grecian vinyl inground
    27 yr old hayward 1hp pump
    27 yr old 36sqft DE filter / multiport valve
    2 surface skimmers / 1 bottom skimmer
    3 return ports
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Redoing pool- need opinions
    Welcome to tfp, timelessr1
    That is a great looking pool! How certain are you of the volume?...36K seems a little large for the dimensions you posted. What depths is it?
    If your pool is 36K gallons then we would recommend as minimums:
    • Cartridge filter: 534 sq. ft.
      Sand filter: 6.7 q. ft.
      DE filter: 100 sq. ft.
    As for swgs, I love mine!
    timelessr1's Avatar
    Jul 2013
    North New jersey
    6
    Thanks linen!
    the deep end is 8 1/2 feet deep..the shallow is 4 feet...its also 21 feet wide..not the normal 20... what are you getting as gallons?
    Whoa!! so i was severly under filtered with the current 36 sqft DE filter??
    it looked like the Jandy cartridge was one of the largest offered...do they even offer larger residential units?
    I was looking at the Pentair IC-60 unit...this way i dont have to run it constantly at a higher %
    36,000 gallons
    3 return ports
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    With those depths I get about 36000 also.
    Yes, we would consider your DE filter undersized. How often did you have to backwash/clean it?
    Jandy, Hayward and Pentair offer cartridge filters that are large in their residential stuff...jandy up to 580, pentair up to 520, hayward up to 725 (also a 525).
    For swgs...we recommend sizing them at least 1.5-3 times the pool size.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by timelessr1
    Wow...This just set a record (to me anyway) for the longest pump life I have heard so far.
    When replacing the pump, I would suggest considering only 2-speed or variable-speed models. The general rule of thumb is if your electric rates are $0.20 per kWh or less, a 2-speed is more cost effective compared to a variable-speed. Above that, a variable-speed becomes more attractive. If your rates are near the borderline, you may want to consider the recent trend in your rates. If they have risen consistently, you may want to opt for the variable-speed. Manufacturers have recently began introducing new variable-speed pumps. This article explains some of these new pumps and is well worth reading.
    BTW, that pool looks fantastic and up-to-date. Never would have guessed it was 27 years old.
    timelessr1's Avatar
    Jul 2013
    North New jersey
    6
    linen- I end up backwashing like once a month...so maybe about 4-5 times during the season.
    Bo- thanks for the info! I'm going to read that article...I'm leaning towards a VS pump and possibly with the EasyTouch, which hopefully I can really dial in the speed of the pump for maximum efficiency of electric usage....I would think a two speed pump wouldn't allow me to really fine tune that..since its either set high or low.
    And thanks...I try to maintain my stuff...but im even shocked that the pump made it this long..on the original bearings! I'll get a pic up soon of the prehistoric pump and filter
    36,000 gallons
    3 return ports
    timelessr1's Avatar
    Jul 2013
    North New jersey
    6
    So this is the miracle pump and filter...hahaha...27 years old...it still works too...it jsut squeals at times...but not always. Its finally time to ugrade though... i couldnt belive it runs at a constant 3450RPMS!!
    36,000 gallons
    3 return ports
    itodd's Avatar
    Jul 2013
    Gastonia, NC
    50
    I have to say I LOVE the smaller pond to the side. That is great. I've always liked the small yard ponds and what a great idea to use it as part of the landscaping.
    4600 gallons, Intex Ultra Metal Frame 14' round 4' depth, SWG, cartridge filter pump, 2500 gph, Pool finish date: 7/16/13.
