Thread: Building code help with railing height on new deck......
    May 2013
    CT
    57
    I am almost done with framing the side pool deck which is roughly a quarter way around the pool and is an extension to my existing attached to the house deck.
    So i know codes vary state to state but a general code is 48" barrier around an above ground pool. Normally the pool itself will be the barrier, but things change when you add a deck.
    I am trying to understand the 48" rule for the railing.
    1) Does the 48" start from the ground, or from the new deck floor?
    I don't think i have ever seen a 48" deck railing before.
    2) Does just the gate have to be 48"?
    I rather get help here before asking the inspector, can anyone explain this or have pics to help me?
    I have googled it and i come up with what i already know.
    18' x 52" AGP 2hp 2 speed pump with Clearwater II 67 GPM DE filter
    200 gallon EZ SPA 1hp 2 speed GREEN pump
    Jun 2013
    SpringHill FL
    415
    Re: Building code help with railing height on new deck......
    Bare minimum any structure 72" off the ground must have railings at least 42" from the top rail to the deck anything under 72" off the ground can be 36" from top rail to the deck. Per national building code ( but state and local code supersedes national code ) If you went 42" off the deck you would be fine imo
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    May 2013
    CT
    57
    Quote Originally Posted by FamilyGuy
    The deck is about 40" off the ground, then in the middle there is a platform which is about 8" on top of that to enter the pool.
    Casey's Avatar
    SW PA
    10,446
    You need to ask the inspector what they require as minimum height because they are the ones who will be inspecting it in the end.
    May 2013
    CT
    57
    Quote Originally Posted by Casey
    I gave in and called him, he came over same day, i am able to install minimum railing size of 36" Only the actual gate has to be 48"
