Thread: Cloudy water?
    Jun 2013
    Seguin TX
    192
    Cloudy water?
    Greetings,
    Been using the BBB method since setting the pool up and have had crystal clear water.
    I keep my FC around 3-5ppm at all times.
    My PH is a little high at 7.8 but I like it there.
    CYA=35
    Bather load, 2 people for about 1.5 hrs each day.
    The only thing I changed was the filter I use, I switched from the standard filter that comes with the Intex "which I cleaned daily" to the Filbur FC-3710.
    I run the pump about 4hrs per day and before changing out the filter was keeping the pool crystal clear.
    Ideas?
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    30,421
    Re: Cloudy water?
    Have you tried switching back to the old filtration or are they gone now?
    Jun 2013
    Seguin TX
    192
    Re: Cloudy water?
    I still have the orig filter I got with the pool. It is clean and ready to use.
    Truth be told, the filter that came with the pool appears to be "better quality" than the Filbur one?
    Seems to have more pleats and better construction, the Filbur filter can be compressed while the orig Intex one cant be crushed. The plastic inside the Intex filter goes from top to bottom while the Filbur has a floating plastic stiffener that floats inside of the core of the filter.
    I thought these Filbur filters were a better grade than the Intex, however I am finding this may not be the case
