Results 1 to 9 of 9
Thread: Heater Location...
    Jul 2013
    Chicago IL
    83
    Heater Location...
    I have a 15 round , in the market for a Rheem 130k heater. BUT, having a deck built around the pool. Would it be safe to put the heater under the deck with pump and filter without burning the house down?. Or do these heaters need to be in the open air?
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    22,548
    Re: Heater Location...
    Is that a heat pump?
    Jul 2013
    Chicago IL
    83
    No .. natural gas heater
    22,548
    I probably wouldn't put a gas heater under the deck. There is a required clearance diagram in the manual. I'm pretty sure it's a large distance above the unit.
    Jun 2013
    SpringHill FL
    415
    They sell hood kits that essentially put a stove pipe on them for indoor use but not sure that would help in your situation
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    It would require some research, but I'm fairly certain there is a method described in the owners manual to vent the heater properly.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Donldson's Avatar
    NW Ohio
    2,893
    The manual shows that there should be nothing above it when installed outdoors. A 42 inch clearance when installed indoors (which I am sure involves proper venting). So if your deck is more than 4 feet high then you can look in to what it would take to properly install and vent it. If it's less than 4 feet then it's not happening.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    22,548
    The manual says "Heaters must not be installed under an overhang of less than 3 ft from the top of the heater. Three sides must be open in the area under the overhang." So theoretically it could be installed under the deck if the deck is 6' high and open on the sides. It'd make a nice foot warmer when you walked across that part of the deck.
    Ft Lauderdale, Florida
    1,455
    Hmmmm, silly response, but.... aren't you getting a carbon monoxide discharge from the gas heater? Unless you have proper ventilation, someone may... uh... die?
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
