Results 1 to 11 of 11
Thread: Wow! I want one of these!
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    This has to be the coolest residential pool I have ever seen. Enjoy.
    http://www.huffingtonpost.com/2013/07/2 ... 72753.html
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Wow! I want one of these!
    Very cool!
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Apr 2012
    Puglia, Italy
    133
    wouldn't let me view it "because of my location"
    400,000 Litre in ground infinity pool, with 40,000 litre holding tank (116 235.703 04 gallon). Vinyl liner.
    Two Astralpool Cantabric sand filters, 900mm diameter, each with 550kg of sand.
    Two ESI MP6 1.5kw 3 phase pumps.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Saw it on youtube...indeed very cool. There is another pool on Lake Travis in Austin TX. Lazy River, 30 person Spa, giant water slide etc. etc.... It's residential and the owner spent 3.3 Million on it. Pretty amazing. He states it cost about 5500 a month to run it.
    I forgot, the monthly cost doesn't include Bartenders.
    Essential Links:
    May 2012
    Northern Connecticut
    103
    Wow...5500 a month to run it??? He must not be using BBB. We could do it for 30 bucks tops!
    24,000 20x42 double roman end in ground pool being built. Start date june13, 2012.
    Finished July 4th, 2012, sports pool, vinyl,SWG, DE filter, fountains. Heat pump,
    First Pool Ever!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I doubt it.
    If you want to see the Lake Travis pool, here it is. Starts at 10:20
    http://youtu.be/RuRcaZQ8Rlg?t=10m20s
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Certainly not cheap with 13 pumps to run it.
    Jun 2012
    Escondido, CA.
    42
    Sorry.. as a diver.. I've dived commercially and recreationally.. its kinda lame..
    That being said.. it is a very nice pool. Our pool is only 9ft at its deepest end.. and I'd love to have a pool thats 20ft deep.. but this pool... is just a pool with a deep end.
    There is nothing like rolling off the back of a boat 12 miles off shore onto a seamount that drop down to 3500 ft
    Escondido Ca [*]~23000 gallon plaster pool built in the 70's[*]Pentair VF Pump running 10hrs at 1800rpm getting and estimated 35-40 GPM thruput[*]Sta-Rite Cartridge filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by BitViper
    But a very cool deep end at that.
    Ever work for COMEX?
    Essential Links:
    Jun 2012
    Escondido, CA.
    42
    Quote Originally Posted by Brushpup
    No.. Those guys are nuts! Lil too deep sometimes too!
    I worked as a contractor (Marine Mammal Trainer), for the Navy's Marine Mammal Program for 14 years.
    Ever seen this pool?
    http://www.victory-cruises.com/pool.html
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yea, you have to be a little nuts to do all that they do. Scary stuff.
    Essential Links:
