Results 1 to 9 of 9
Thread: Hand towel sucked up by pool pump!!!
    I had a hand towel sucked up thru my skimmer today. I was cleaning out basket and daughter dropped in. Any ideas on how to remove?
    12,500 IG, SWG,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Hand towel sucked up by pool pump!!!
    plumber's snake.
    Which side.. Pump side or skimmer side? Not sure where its stuck. I would say there's probably 75 feet of pipe between the 2.
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by Mikep080982
    My guess is it's probably stuck at the first elbow, so I'd start at the pool end.
    I'd also look into buying a dedicated snake, since you don't want what's on an older one in your pool.
    Thanks so much. Just to added question... What's the difference between a plumbers snake and a dedicated snake?
    Jul 2013
    Swartz Creek, MI
    67
    Dedicated pool use only. Never in the toilet.
    45ish year old, 16x32, 19,000, IG, Concrete/Fiberglass Hybrid in need of restoration
    Sand filter with 3/4 hp AO Smith pump. 1 skimmer, 1 main drain, 1 return
    Oh... Haha. Thank you sir!
    mmn's Avatar
    Jul 2013
    South Florida
    34
    The dedicated one shows up on time? Sorry... :P
    14,288 gal IG freeform Diamondbrite
    Hayward 9002 filter
    3/4 hp Hayward pump
    Barracuda G3 cleaner
    TF-100 test kit
    resurfaced 6/2013
    Lol
